[Zoo-discuss] File libzoo_service.so.1.5 doesn't get installed
Fenoy Gerald
gerald.fenoy at geolabs.fr
Tue Dec 13 02:50:18 PST 2016
Dear Jacinto,
I meant that the location of the libzoo_service.so should be found in the LD_LIBRARY_PATH.
If you have added the location of your library to the /etc/ld.so.conf file, it should be available system wide rather than only defined in your terminal (in case you use export LD_LIBRAR_PATH).
What you can also try to make sure your library can be found, is using the following command:
ldd zoo_loader.cgi
In case you you have any library not found, it means something is wrong in the definition of the location of your library or it is not taken into account.
I hope this helps.
Best regards,
> Le 13 déc. 2016 à 11:43, Jacinto Estima <jacinto.estima at gmail.com> a écrit :
> Dear Gérald,
> Thank you for your prompt reply.
> When you say that the library is not in the search PATH, did you mean the $PATH env variable?
> Thanks,
> Jacinto
> On Tue, 13 Dec 2016 at 12:30 Fenoy Gerald <gerald.fenoy at geolabs.fr> wrote:
> Dear Jacinto,
> once you have run the make install, then you should have everything setup correctly.
> Nevertheless, if the libzoo_service.so is not found, it means that the location of the library (probably /usr/local/lib) is not in the search PATH, you may check in /etc/ld.so.conf or in /etc/ld.so.conf.d (depending on your Linux distribution). In other case, it may also come from the ldconfig tool that should be run to update and take into account new PATH added to the library path (LD_LIBRARY_PATH if I recall well).
> I hope this helps you to solve your issue.
> Best regards,
> > Le 13 déc. 2016 à 09:06, Jacinto Estima <jacinto.estima at gmail.com> a écrit :
> > Dear list,
> > I am new to the ZOO project.
> > I was trying to install it in UBUNTU 16.04 32 bit running on a virtualbox virtual machine.
> > I followed all the instructions available at http://www.zoo-project.org/docs/install/debian.html but when a do "sudo make install" inside zoo-kernel, the file libzoo_service.so.1.5 doesn't get installed. The files libzoo_service.so and zoo_loader.cgi are there. I did all the remaining steps and when I tried to access the GetCapabilities I got the following error in the apache error log:
> > [Tue Dec 13 11:39:51.543837 2016] [cgi:error] [pid 5892] [client 127.0.0.1:38330] AH01215: /usr/lib/cgi-bin/zoo_loader.cgi: error while loading shared libraries: libzoo_service.so.1.5: cannot open shared object file: No such file or directory: /usr/lib/cgi-bin/zoo_loader.cgi
> > Anyone that could help me figure this out?
> > Thank you very much,
> > Jacinto
> > Zoo-discuss mailing list
> > Zoo-discuss at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/zoo-discuss
> Gérald Fenoy
> http://wiki.osgeo.org/wiki/User:Djay
Gérald Fenoy
More information about the Zoo-discuss
