[Zoo-discuss] Error in compiling Rev. 773 with Java Support
rakesh prithiviraj
rakeshuk at outlook.com
Mon Jun 13 05:24:12 PDT 2016
Thanks Gerald for the fix. I confirm that this issue is no longer occurring with Rev. 774.
Regards
> Subject: Re: [Zoo-discuss] Error in compiling Rev. 773 with Java Support
> From: gerald.fenoy at geolabs.fr
> Date: Mon, 13 Jun 2016 12:09:53 +0200
> CC: zoo-discuss at lists.osgeo.org
> To: rakeshuk at outlook.com
> Hi Rakesh,
> sorry for late reply.
> You can find, in revision 774 the fix about the issue you have reported which is relative to the yaml support.
> I hope you can confirm that this solves your issue. Please also note that the Java ZOO-API has been slightly modified, it is now defined in a org.zoo_project package.
> Best regards,
> > Le 12 juin 2016 à 17:07, rakesh prithiviraj <rakeshuk at outlook.com> a écrit :
> > Hi,
> > I updated zoo-project to latest revision 773 and could no longer compile ZOO-API for java.
> > worker at vm-04:~/02-Installations/zoo-project/zoo-project/zoo-kernel$ ./configure --with-python --with-java=/usr/lib/jvm/java-7-openjdk-amd64/
> > This worked fine.
> > Compiling ZOO-API for java throws error:
> > worker at vm-04:~/02-Installations/zoo-project/zoo-project/zoo-api/java$ make
> > javac org/zoo_project/ZOO.java
> > javah org.zoo_project.ZOO
> > gcc -fPIC -c zoo-api.c -I/usr/lib/jvm/java-7-openjdk-amd64//include -I/usr/lib/jvm/java-7-openjdk-amd64//include/linux -I/usr/include/libxml2 -I../../zoo-kernel/ -I../../../thirds/cgic206/
> > gcc zoo-api.o -shared -o libZOO.so -Wl,../../zoo-kernel//service_yaml.o,../../zoo-kernel/lex.cr.o,../../zoo-kernel/main_conf_read.tab.o,../../zoo-kernel/lex.sr.o,../../zoo-kernel/service_conf.tab.o,../../zoo-kernel/service_internal.o,../../zoo-kernel/server_internal.o,../../zoo-kernel/response_print.o,../../zoo-kernel/service_internal_java.o,../../zoo-kernel/service_internal_js.o,../../zoo-kernel/ulinet.o -L/usr/lib -lgdal -lxml2 -L/usr/lib/python2.7/config-x86_64-linux-gnu -L/usr/lib -lpthread -ldl -lutil -lm -lpython2.7 -Xlinker -export-dynamic -Wl,-O1 -Wl,-Bsymbolic-functions -L/usr/lib/jvm/java-7-openjdk-amd64//jre/lib/amd64/server/ -ljvm -lpthread -L/usr/lib -lmozjs185 -lm -lcrypto -lcurl -lfcgi -lzoo_service -lyaml
> > /usr/bin/ld: cannot find ../../zoo-kernel//service_yaml.o: No such file or directory
> > collect2: error: ld returned 1 exit status
> > make: *** [libZOO.so] Error 1
> > Before the update, I had no issues. the following is the working output.
> > ftep at worker-01:~/02-Installations/zoo-project/zoo-project/zoo-api/java$ make
> > javac ZOO.java
> > javah ZOO
> > gcc zoo-api.o -shared -o libZOO.so -Wl,../../zoo-kernel/service_internal.o,../../zoo-kernel/service_internal_java.o,../../zoo-kernel/ulinet.o -L/usr/lib -lgdal -lxml2 -L/usr/lib/python2.7/config-x86_64-linux-gnu -L/usr/lib -lpthread -ldl -lutil -lm -lpython2.7 -Xlinker -export-dynamic -Wl,-O1 -Wl,-Bsymbolic-functions -L/usr/lib/jvm/java-7-openjdk-amd64//jre/lib/amd64/server/ -ljvm -lpthread -lcrypto -lcurl -lfcgi
> > Could you please let me know if I need to install any specific package for YAML. I am not compiling ZOO-kernel with YAML support. Tested on Ubuntu 14.04.
> > Thanks,
> > Rakesh
> > Zoo-discuss mailing list
> > Zoo-discuss at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/zoo-discuss
> Gérald Fenoy
> http://wiki.osgeo.org/wiki/User:Djay
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20160613/164f4d89/attachment-0001.html>
More information about the Zoo-discuss
