[Zoo-discuss] ZOORequest class is missing
François Dodé
dode.francois at gmail.com
Wed May 24 01:21:49 PDT 2017
Hello Gerald,
Thank you when I set the cookie it's work but it's not expected processing.
Sorry for being not clear.
For exemple when I do the GET request with CURL it's working without set a
cookie in the headers request:
*curl -v
"http://<host>/crv/<key>/doSomething?p1=ZH&p2=ZH&p3=3&p4=46.6947&p5=-2.8564"*
Here the log :
** About to connect() to <host> port 80 (#0)
** Trying xxx.xxx.xxx.xxx... connected
** Connected to <host> (**xxx.xxx.xxx.xxx**) port 80 (#0)
*> GET /crv/<key>/**doSomething?p1=ZH&p2=ZH&p3=3&p4=46.6947&p5=-2.8564*
* HTTP/1.1 *
*> User-Agent: curl/7.19.7 (x86_64-redhat-linux-gnu) libcurl/7.19.7
NSS/3.27.1 zlib/1.2.3 libidn/1.18 libssh2/1.4.2 *
*> Host: **<host>*
*> Accept: */*
*< HTTP/1.1 200 OK
*< Server: nginx
*< Date: Wed, 24 May 2017 07:53:24 GMT
*< Content-Type: text/html; charset=utf-8
*< Vary: Accept-Encoding
*< Set-Cookie: route=abe6a29b89be7b9be8f1bf07ea11b863; Path=/
*< X-Powered-By: Express
*< Content-Length: 29
*< X-Cache: xxxxxxxx
*< X-Cache-Lookup: xxxxxxxxx
*< Connection: keep-alive
** Connection #0 to host <host> left intact
** Closing connection #0*
The cookie is set in the response header and the first time I request the
service, no cookies are set.
So in the JS file I have just to do that : ZOO.Request.Get(url,
params)
But it's fails due to an segmentation fault when the ulinet set the
response header at line "Set-Cookie: "
I add log in the ulinet programs for show this :
** About to connect() to <host> port 80 (#0)*
** Trying xxx.xxx.xxx.xxx... connected*
** Connected to <host> (xxx.xxx.xxx.xxx) port 80 (#0)*
*> GET /crv/<key>/doSomething?p1=ZH&p2=ZH&p3=3&p4=46.6947&p5=-2.8564
HTTP/1.1*
*User-Agent: ZooWPSClient*
*Host: <host>*
*Accept: */**
*< HTTP/1.1 200 OK*
*[DEBUG - ulinet] In function header_write_data*
*< Server: nginx*
*< Date: Wed, 24 May 2017 08:09:39 GMT*
*< Content-Type: text/html; charset=utf-8*
*< Vary: Accept-Encoding*
** Added cookie route="abe6a29b89be7b9be8f1bf07ea11b863" for domain <host>,
path /, expire 0*
*< Set-Cookie: route=abe6a29b89be7b9be8f1bf07ea11b863; Path=/*
*[DEBUG - ulinet] Variable tmp: route=abe6a29b89be7b9be8f1bf07ea11b863*
*[DEBUG - ulinet] the line before sprintf(CCookie[psInternet->id],"",tmp);*
I hope it's help you for understand the issue.
Best regards
2017-05-23 14:01 GMT+02:00 Fenoy Gerald <gerald.fenoy at geolabs.fr>:
> François,
> you should try using the revision 828.
> You should consider using the new version of ZOO-API.js it contains.
> There were no support for passing any headers to GET request from the js
> ZOO-API.
> I have modified the ZOO-API to enable this support.
> Still, note that defining conf["lenv"]["cookie"] is required only for
> services that are supposed to produce a session environment and a linked
> Cookie is generated and returned to the client application. So it is not
> the way to pass headers to your requests from the js ZOO-API.
> You can use the following syntaxe from your js code:
> var i=ZOO.Request.Get("http://www.gogle.com/",{"toto":"toto"},{"Cookie":
> "XXX=XXXXXXXX01"});
> or
> var i=ZOO.Request.Get("http://www.gogle.com/",{"toto":"toto"},["Cookie:
> XXX=XXXXXXXX01;"]);
> I hope it helps.
> Gérald Fenoy
> http://wiki.osgeo.org/wiki/User:Djay
> > Le 23 mai 2017 à 10:39, François Dodé <dode.francois at gmail.com> a écrit
> > Hello,
> > Thank you. I tested this revision but it fails. I have a segmentation
> error.
> > The line where the program fail is 97 :
> > sprintf(CCookie[psInternet->id],"%s",tmp);
> > The value in the tmp variable is correct.
> > Maybe I do wrong when I declare the cookie in the JS file.
> > In the JS file I add this line :
> > conf["lenv"]["cookie"]="XXX=XXX1000000; path=/";
> > and after that I do the ZOO.Request.Get
> > Also in the ulinet.h, the prototype was not change to :
> > bool setProxiesForProtcol(CURL*,const char*);
> > Best regards
> > 2017-05-22 21:33 GMT+02:00 Fenoy Gerald <gerald.fenoy at geolabs.fr>:
> > Thanks for your feedback.
> > The previous ulinet.c version was containing an error. Please can you
> give revision 827 a try ?
> > I suppose it will solve your issue.
> > Best regards,
> > Gérald Fenoy
> > > Le 22 mai 2017 à 17:36, François Dodé <dode.francois at gmail.com> a
> écrit :
> > > Thank you for your presicions.
> > > I have noticed an issue in the file ulinet.c of 825 revision :
> > > The env variable is undeclared in the function header_write_data but
> use in line 96.
> > > For test I set : char env[256]
> > > I don't know if it's the right correction but I when I do GET request
> on web service who send cookies to the client the ZOORequest failed.
> > > 2017-05-22 14:56 GMT+02:00 Fenoy Gerald <gerald.fenoy at geolabs.fr>:
> > > François,
> > > sorry for being not clear.
> > > In the file ZOOMakefile.opts (generated by the configure script, so
> you may also edit ZOOMakefile.opts.in in case you run the ./configure
> command again) you should add to you CFLAGS definition the following
> option: -DMSG_LAF_VERBOSE. Then remove any ulinet.o already built and run
> make again.
> > > I hope it helps.
> > > Best regards,
> > > Gérald Fenoy
> > > > Le 22 mai 2017 à 14:52, François Dodé <dode.francois at gmail.com> a
> écrit :
> > > > Hello,
> > > > Thank you.
> > > > I tested to add MSG_LAF_VERBOSE= -DMSG_LAF_VERBOSE in the zoo-kernel
> Makefile but it's not working.
> > > > In the main.cfg I put this in the main section:
> > > > logPath = /var/log/zoo/out.log
> > > > But nothing is log when I use the ZOO.Request.Get in the script
> hello.js :
> > > > ./zoo_loader.cgi "Request=Execute&service=WPS&
> Identifier=hellojs&version=1.0.0&DataInputs=S=test"
> > > > Best regards
> > > > 2017-05-22 10:21 GMT+02:00 Fenoy Gerald <gerald.fenoy at geolabs.fr>:
> > > > Hello François,
> > > > sorry for late reply.
> > > > In case you want to debug the CURL call used for every internal HTTP
> request and the one coming from the JS ZOO-API call, then you can define
> the MSG_LAF_VERBOSE variable at compilation time to produce a debug
> version. Once you have added the -DMSG_LAF_VERBOSE in your Makefile, simply
> remove the ulinet.o and run the make command again.
> > > > In case you need only to debug the result returned by the ZOO-API
> call, then you can simply use the alert function from the ZOO-API to
> display debug messages in your web server error log file. In case you want
> to handle exception you can then use basic try / catch blocks.
> > > > I hope it helps.
> > > > ps: I have noticed that the discussion is not available to the
> public, you may think of answering this email using the ZOO-Discuss mailing
> list. What you are asking may be of interest to other also.
> > > > Gérald Fenoy
> > > > > Le 20 mai 2017 à 19:26, François Dodé <dode.francois at gmail.com> a
> écrit :
> > > > > Hello Gerald,
> > > > > Thanks a lot for your help. Now it's work perfectly with the new
> revision.
> > > > > I think I had an old revision.
> > > > > Another question, how can I get log from the ZOORequest and handle
> exceptions ?
> > > > > Best regards,
> > > > > Dodé François
> > > > > 2017-05-17 14:55 GMT+02:00 Fenoy Gerald <gerald.fenoy at geolabs.fr>:
> > > > > Hello François,
> > > > > thanks for the feedbacks about this issue.
> > > > > May I ask you to build a new ZOO-Kernel using the revision 825 [1]
> ? This version should solve this issue.
> > > > > I hope to hear back from you.
> > > > > Best regards,
> > > > > [1] http://www.zoo-project.org/trac/changeset/825
> > > > > > Le 17 mai 2017 à 10:25, François Dodé <dode.francois at gmail.com>
> a écrit :
> > > > > > Hello Gerald,
> > > > > > Thank you for your quick response.
> > > > > > Maybe it's my install of mozjs. I run the ZOO on CentOs 6 and I
> had to build this library.
> > > > > > Here is the library :
> > > > > > http://ftp.mozilla.org/pub/js/js185-1.0.0.tar.gz
> > > > > > I add the request GET in the script hello.js.
> > > > > > My Javascript process call the ZOO.Request.Get like this :
> > > > > > ZOO.Request.Get("http://www.google.fr/")
> > > > > > I put the result in the alert() function.
> > > > > > Best regards,
> > > > > > Dodé François
> > > > > > 2017-05-12 19:42 GMT+02:00 Fenoy Gerald <gerald.fenoy at geolabs.fr
> > > > > > Hello François,
> > > > > > ZOORequest shall be defined at runtime by the ZOO-Kernel [1].
> > > > > > Are you sure the issue comes from call to ZOO.Request.Get ?
> > > > > > Can you please provide more details about your JavScript service
> > > > > > Best regards,
> > > > > > [1] http://www.zoo-project.org/trac/browser/trunk/zoo-
> project/zoo-kernel/service_internal_js.c#L152
> > > > > > > Le 12 mai 2017 à 16:06, François Dodé <dode.francois at gmail.com>
> a écrit :
> > > > > > > Hello,
> > > > > > > I want to make a GET request with the ZOO-api but I have the
> following error :
> > > > > > > <ows:Exception exceptionCode="InternalError">
> > > > > > > <ows:ExceptionText>ZOO Kernel failed to process your
> request, receiving signal 11 = SIGSEGV</ows:ExceptionText>
> > > > > > > </ows:Exception>
> > > > > > > In the ZOO-api.js in the function ZOO.Request.Get(url, params)
> it returns a class named ZOORequest but this class doesn't exist.
> > > > > > > Have you a solution ?
> > > > > > > Best regards
> > > > > > > _______________________________________________
> > > > > > > Zoo-discuss mailing list
> > > > > > > Zoo-discuss at lists.osgeo.org
> > > > > > > https://lists.osgeo.org/mailman/listinfo/zoo-discuss
> > > > > > Gérald Fenoy
> > > > > Gérald Fenoy
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20170524/87017d38/attachment-0001.html>
More information about the Zoo-discuss
