[Zoo-discuss] ZOO Project with MapServer (WIndows 10)
MAYANK JASORIA f2016703 at pilani.bits-pilani.ac.in
Sun Jul 1 23:36:33 PDT 2018
Just a follow up to the previous email,
Although the mapfile is generated successfully and both GetMap (WMS) and
GetFeature (WFS) requests are working, two files, a .data file and a .zip
file are also generated with each request and for every request, the
zoo-error log says "Unable to access the DataSource as ZIP File".
Is this some configuration error which is perhaps also related to the
previous email?
ᐧ
On Mon, Jul 2, 2018 at 11:37 AM, MAYANK JASORIA <
f2016703 at pilani.bits-pilani.ac.in> wrote:
> I have got MapServer working fine now. Thanks for the help.
> I finally ended up passing GML3 to generate the mapfile from the WPS
> service with MapServer. The problem is that this mapfile does not seem to
> support WMS GetFeatureInfo. Are there some additional configuration steps
> required to add that? (The generated mapfile does not contain any TEMPLATE
> element.)
> Please Help. Thanks in advance
> ᐧ
> On Fri, Jun 29, 2018 at 9:01 PM, Gérald Fenoy <gerald.fenoy at geolabs.fr>
> wrote:
>> Mayank,
>> I suppose you may have better result using this version of the installer
>> [1].
>> For being able to use « Shapefile as input », you should provide a zip
>> file containing all the files associated with it.
>> When you say the image is resized in the image you get when accessing the
>> returned GetMap url, it is probably due to the fact that the GetMap
>> returned use the WGS84 projection (EPSG:4326). Nevertheless, the published
>> mapfile (first part of the URL) can be accessed through a WMS client to
>> display it in another supported projection system, such as Spherical
>> Mercator (EPSG:3857) used by traditional tile providers.
>> I hope this helps.
>> Regards,
>> [1] https://bintray.com/gfenoy/ZOO-Project/Windows-Binaries/1.6.
>> 0-rc2#files
>> Gérald Fenoy
>> http://wiki.osgeo.org/wiki/User:Djay
>> > Le 29 juin 2018 à 16:36, MAYANK JASORIA <f2016703 at pilani.bits-pilani.a
>> c.in> a écrit :
>> > I am using ZOO Project 1.5.0 installed using
>> ZOO-Project-Installer-x64-72.exe.
>> > For MapServer I followed the instructions to host MapServer on IIS
>> according to this link: MapServer on IIS (MapServer version 7.0.7).
>> > As for the data that I want to process, I was initially under the
>> impression that it should be some result from WMS GetMap request as GDAL
>> does list image/png, image/geotiff etc. as a valid input accepting rasters
>> (MapServer input formats). However, it does make sense that I needed the
>> data from a WFS GetFeature request, unlike my previous thoughts. I also
>> tested the geotiff8 input for multiple cases and found that after a point
>> it started to fail miserably, giving outputs which were very far off from
>> the actual data. Sorry for this confusion, I'm pretty new to this.
>> > Now when I tried WFS GetFeatures, it seems to work fine for GML 3.
>> However, if I try to pass a shapefile, I see the same errors which I
>> reported for other formats. I tried this on a script that I wrote instead
>> of HelloPy though as it is easier to try the returned GetMap URL (from
>> MapServer) here. Also, I found that the KML error was because of an error
>> on my part.
>> > There is another thing though. Now the images that I am getting are
>> getting resized instead of maintaining the actual shape which it should, to
>> align properly on a map. I am not sure of the reason though I guess it is
>> because the image is getting resized according to the width and height
>> parameters in the GetMap request returned from MapServer.
>> > Could you please guide me on the shapefile and image resizing issue?
>> > Thank you very much for your help.
>> > On Fri 29 Jun, 2018, 5:56 PM Gérald Fenoy, <gerald.fenoy at geolabs.fr>
>> wrote:
>> > Dear Mayank,
>> > there are few things I am not sure to understand correctly in your
>> email.
>> > You say that you want to process data coming from a GetMap request, I
>> guess that you want to process the data coming from a GetFeature request.
>> Indeed, in case you want to process any WPS service on vector data you
>> should then use a WFS GetFeature request. You may be willing to process
>> raster data but, in such a case, we usually use a WCS GetCoverage  request
>> rather than a WMS GetMap one.
>> > Also, you make mention of using HelloPy to access your data,
>> nevertheless, HelloPy service does not except any binary data but a string
>> only. So, I suppose that there may be some issue when trying to convert
>> your binary data to a string. Still, it should not occur.
>> > You also said that when you pass a geotiff you are getting the required
>> results, I would like to be sure that the produced files contain what you
>> expect as a result. Can you please confirm you are getting the proper
>> output?
>> > I would like to be sure of what is the version of the ZOO-Project you
>> are using on your windows platform. What is the installer you have used? I
>> guess the best choice available currently is MS4W.
>> > I hope to hear back from you.
>> > Best regards,
>> > > Le 27 juin 2018 à 08:18, MAYANK JASORIA <
>> f2016703 at pilani.bits-pilani.ac.in> a écrit :
>> > > Dear all,
>> > > I am working on a service which fetches some data via a getMap WMS
>> request to GeoServer. This is then supposed to give me a GetMap request URL
>> from the mapfile generated by MapServer, which once made would return the
>> WMS layer as required. The problem is that for all formats of data returned
>> by GeoServer except image/geotiff8, I am getting  ZOO Kernel failed to
>> process your request, receiving signal 11 = SIGSEGV error. The same is
>> happening if I pass any such data to HelloPy (according to the test method
>> on the ZOO website).
>> > > If I pass Geotiff8 however, I am getting the required results.
>> > > Two files, a .data file and a .zip file are generated with each
>> request. Also, for every request, the zoo-error log says "Unable to access
>> the DataSource as ZIP File", along with different messages (sometimes none)
>> for different formats of data passed.
>> > > For the following formats, a .map file is generated, but the SIGSEGV
>> error persists.:
>> > >       • image/jpeg
>> > >       • image/geotiff
>> > >       • kml
>> > >       • rss
>> > > Zoo Project was installed using the installer and MapServer 7.0.7 are
>> installed.
>> > > If some more information is needed, I have posted a question here.
>> > > I would be highly obliged if someone could help me.
>> > > ᐧ
>> > > _______________________________________________
>> > > Zoo-discuss mailing list
>> > > Zoo-discuss at lists.osgeo.org
>> > > https://lists.osgeo.org/mailman/listinfo/zoo-discuss
>> > Gérald Fenoy
>> > ᐧ
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20180702/7bd6de5a/attachment-0001.html>
More information about the Zoo-discuss mailing list
