[Zoo-discuss] ZOO-Project 1.9.0 release candidate 1
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Jan 25 11:15:59 PST 2022
Dear Gérald,
Thank-you for this effort.
Please also add to your release process: creating the RC & releases at
https://github.com/ZOO-Project/ZOO-Project/releases
(for example, I like how GRASS GIS team lists the release candidates at
https://github.com/OSGeo/grass/releases Or you can see how I do it at
https://github.com/MapServer/MapServer/releases )
Once you click the "Create a new release" button there, then GitHub
automagically notifies the repository's "followers".
Thanks,
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
http://gatewaygeo.com/
On 2022-01-25 2:56 p.m., Gérald Fenoy wrote:
> Dear community,
> As Release Manager, I am glad to announce the publication of the
> ZOO-Project 1.9.0 release candidate 1.
> It can be downloaded from here [1].
> This new ZOO-Project release contains new features but also fixes.
> In November 2021, the Open Geospatial Consortium approved the OGC API -
> Processes (Part 1: Core) standard. The new ZOO-Project release supports
> this newly approved version. The MapServer support was integrated with
> this new standard, even if the output data are only available through
> WMS, WFS and WCS OGC standards, by now (see issue #1 [2]).
> =-= New Features and Fixes =-=
> * Update ZOO-Kernel internal messages natural languages po files
> * Fix issue with synchronous execution from the HTML UI when requesting
> something else than raw data output.
> * Add support for natural languages to be available within the
> docker-compose setup.
> * Add support for automatic natural languages support.
> * Add getValueFromMaps function the C-API to be used from C services
> requiring to be functional in every memory management mode (load or
> protected)
> * Add support for datetime parameter for jobs filtering as defined in
> OGC API - Processes.
> * Add support for type parameter for jobs filtering as defined in OGC
> API - Processes.
> * Add support for minDuration and maxDuration parameters for jobs
> filtering as defined in OGC API - Processes.
> * Change the table structure for storing ongoing execution status
> informations to add required field for outputing correct statusInfo.
> * Addition in the C-API: function addToMapA, in case there is already a
> value, then the value is appended to the string and values are coma
> separated (reason of the change: support for filtering using processId
> and status in OGC API - Processes).
> * Add support for filtering using array of string the jobs list from OGC
> API - Processes using processId or status parameter
> * Change docker-compose to use binary docker image published from GitHub
> action.
> * Minor updates in docker-compose to target the right arch and
> potentially cross compile in case you run from another arch
> * Get back the MapServer automatic publication of outputs/results
> through OGC Web Services (WMS, WFS, and WCS)
> * Update the Basic HTML UI to use the Prefer header in case the
> execution scenario requires to run the execute request asyncrhonously
> * Support the Prefer header for choosing between execution mode
> scenarios which can be sync/async and raw/document
> * Add support for multiple output requested as Raw for OGC API -
> Processes (why not backport this in WPS?)
> * Automatically add the old format of metadata informations to the
> inputs and outputs to not require a single modification within your
> existing services
> * Update the Basic HTML UI to try to conform to version 1.0-draft.6
> * Modify both the request parser and response printer functions from the
> C-API to conform to version 1.0-draft.6
> * Support both the old array of inputs / outputs syntax and the one
> defined in the draft 1.0-draft.6 (array of inputs for the new syntax may
> not work as expected)
> * Move jobs to root and use /processes/{processID} as execute endpopint
> * Make all demos running within docker (including SAGA and OTB)
> * Deploy demo HTML UI from github from the Dockerfile
> * Add demo ZOO-Services build in the Dockerfile
> Please report any issue you may have using this version.
> In case no issue is reported in the 7 upcoming days, we will approve
> this release candidate.
> Best regards,
> [1] http://zoo-project.org/new/Code/Download
> <http://zoo-project.org/new/Code/Download>
> [2] https://github.com/ZOO-Project/ZOO-Project/issues/1
> <https://github.com/ZOO-Project/ZOO-Project/issues/1>
> Gerald Fenoy
> Chair, ZOO-Project PSC
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/zoo-discuss
More information about the ZOO-discuss
