[Zoo-discuss] Encountering errors with OGC API while using of multipart/form-data.
Gérald Fenoy
gerald.fenoy at geolabs.fr
Mon Nov 4 07:35:03 PST 2024
Hi Illia,
It's nice to hear that you are interested in the project.
I don’t understand why you want to use « multipart/form-data » with OGC API - Processes. I suppose it is for the execute request to POST to the Server Instance.
For execute requests, there is no multipart supported; you need to provide references of your inputs in the execute request.
It should work if you need a multipart/related response (see Table 11 from [1]), even if we never use it in practice.
I hope this helps.
Best regards,
Side note: I sent this email a while ago, but it was never received.
[1] https://docs.ogc.org/is/18-062r2/18-062r2.html#sc_execute_response
Gerald Fenoy
gerald.fenoy at geolabs.fr <mailto:gerald.fenoy at geolabs.fr>
Chair, ZOO-Project PSC
> Le 24 oct. 2024 à 12:40, Illia Pidosynnyk via ZOO-discuss <zoo-discuss at lists.osgeo.org> a écrit :
> Hello everyone,
> I am very interested in your project, especially the implementation of the OGC API, as it fits perfectly with my task to use the OGC API and GDAL to transform one vector data format into another. However, I keep encountering an error when trying to use multipart/form-data.
> I would like to clarify if support for this format is implemented in your OGC API. If so, are there any additional settings or instructions I should follow to use it correctly?
> If it is not implemented, could you kindly advise on the direction I should take to add this implementation?
> Thank you in advance for your assistance!
> Best regards,
> Illia Pidosynnyk
> ZOO-discuss mailing list
> ZOO-discuss at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/zoo-discuss
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20241104/e1282ed5/attachment.htm>
More information about the ZOO-discuss
