[ZOO-PSC] FOSS4G 2011 Abstract
Gérald Fenoy gerald.fenoy at geolabs.fr
Fri Apr 15 01:34:44 PDT 2011
Dear PSC,
you will find here the abstract I've submited for the FOSS4G 2011 conference.
Title : Introduction to ZOO-Project
Content :
ZOO-Project is a WPS (Web Processing Service) open source project released in April 2010 under a MIT/X-11 style license . It provides an OGC WPS 1.0.0 compliant developer-friendly framework to create and chain WPS Web services. ZOO-Project is made of three parts:
ZOO-Kernel: a server-side C Kernel which makes it possible to manage and chain Web services coded in several programming languages.
ZOO-Services : a growing suite of example Web services based on various Open Source libraries such as GDAL/OGR, GRASS7 and integration on independent simulation models coded in Fortran.
ZOO-API : A server-side JavaScript API able to call and chain the ZOO Services, which makes the implementation of complex geoprocessing workflows easy.
This presentation first aims to present ZOO-Project along with some common use cases.
The presentation will also highlight improvements that were made since the project inception and the ZOO-Kernel-1.0 release in April 2010. ZOO-Kernel-1.2.0 new features that includes GetStatus service and Session cookies management, as documentation and packaging effort (autotools improvements, Mac Installer, OpenSuse packages...).
Further, a number of sucessful experiments that were carried with new ZOO Services will be described. Indeed, ZOO 1.2 now supports GRASS7 thanks to the Python WPS-bridge, and this significantly extends the ZOO based services with a variety of advanced spatial algortithms. Some other experiments using GDAL and MapServer will be shown as an example of how complex processes can be simply chained and orchestrated using the JavaScript ZOO API.
Another interesting research using ZOO-Kernel Java support on the Cloud will also be described. The grid implementation allows to deploy ZOO-Project on the Sun Grid Engine to run complex GPS pocessing algorithms implemented in goGPS project (www.gogps-project.org).
Finally, the use of GDAL/OGR and GRASS7 ZOO-Services through from both OpenLayers applications and the Quantum GIS WPS Client plugin will be shown.
It is really unfortunate that when you submitted an abstract for foss4g you can't modify anything from it ...
I've setup Venka, Nick and I (in reverse order) as authors,
Best regards,
Gérald Fenoy
ZOO-PSC Chair
URL: <http://lists.osgeo.org/pipermail/zoo-psc/attachments/20110415/46a27229/attachment.html>
More information about the Zoo-psc mailing list
