[ZOO-PSC] [Zoo-discuss] Releasing 1.5.0-rc1
David Saggiorato david at saggiorato.net
Fri Jul 3 00:47:10 PDT 2015
+1
Many Thanks to Gerald and Nicolas for this new release
Le jeudi 02 juillet 2015 à 20:31 +0200, Fenoy Gerald a écrit :
> Dear ZOO-PSC,
> I propose to the PSC to vote to release a 1.5.0-rc1 version of the ZOO-Project, with me as release manager.
> The new release includes the following changes and bug fixes :
>   * Complete rewrite of the documentation to use modern style
>   * Fix asynchronous POST request on WIN32 platforms
>   * Add utils/registry service
>   * Initial support for WPS 2.0.0 including the Dismiss extension
>   * Fix concurrency access to status informations
>   * Use simple file rather than shared memory for storing status informations
>   * Add support for db backend to store status informations
>   * Add the lib_zoo_service shared library to be linked against C services
>   * Add ZOO-API for the PHP language (with documentation)
>   * Add doxygen comments in source code
>   * Add support for multiple Exception nodes
>   * Add a length key when creating MapArray
>   * Add OTB support for applications as a service
>   * Add the otb2zcfg utility to produce zcfg for otb applications
>   * Add OTB Application Observer to have progress status updates
>   * Fix maxOccurs handling
>   * Fix gesture of downloaded inputs when multiple values are given
>   * Add detection of generated_file key in outputs to read the file
>   generated by a service
>   * Add a minimal parsing API
>   * Run validateRequest (download, default settings and decoding)
>   after fork if any
>   * Add SAGA-GIS support for modules as a service
>   * Add saga2zcfg utility to generate zcfg for SAGA-GIS modules
>   * Add SAGA-GIS Observer to have ongoing status updates
> I will wait for the PSC members to vote to activate the release procedure [1].
> Best regards,
> [1] http://www.zoo-project.org/docnew/docs/_build/html/contribute/release.html
> Gérald Fenoy
> http://wiki.osgeo.org/wiki/User:Djay
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/zoo-psc/attachments/20150703/c8615675/attachment.pgp>
More information about the Zoo-psc mailing list
