[ZOO-PSC] Call for vote: ZOO-Project 1.6.0 release
hayashi at apptec.co.jp hayashi at apptec.co.jp
Fri Jan 13 00:30:58 PST 2017
++1  for a 1.6.0 release
Happy new year Greald!! :)
On 2017/01/11 22:55, Fenoy Gerald wrote:
> Dear PSC members,
> first of all I wish you all a happy and fruitful 2017 year!
> I wish also the same to the project itself :)
> To start well with this new year, I would like to request you for a vote on releasing the 1.6.0 version.
> We have made various improvements in different places over the past year and it is more than time to release all that changes, sorry for not being able to handle this release earlier last year as it should be. Here is an overview of modifications made in the 1.6.0-dev (current trunk) version:
>   * Add the C# as a supported programming language for Services
>   * Add nested inputs and outputs support (WPS 2.0.0)
>   * Add servicePath special key to specify the service location
>   * Add --with-etc-dir option to specify the location of the main.cfg file
>   * Support GDAL version 2.1.0.
>   * Add the MapServer 7.0.1 internal support.
>   * Support for exotic location of openssl.
>   * Add ZOO-Client API documentation reference in the official documentation.
>   * Add CORS support.
>   * Fix issue when dealing with Array in JavaScript support.
>   * Update the Centos installation procedure.
>   * Small fixes in java support.
>   * Fix issue when XML request contains empty nodes for inputs
>   * Add status update for contour lines computation
>   * Fix FASTCGI location using the --with-fastcgi option.
>   * Redefined the API function addToMapWithSize to fix problem with Python/PHP support.
> I hope to have your vote soon for being able to proceed.
> Obviously I am +1 for this release to happen.
> Best regards,
> Gérald Fenoy
> http://wiki.osgeo.org/wiki/User:Djay
> Zoo-psc mailing list
> Zoo-psc at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/zoo-psc
OSGeo.JP
  http://www.osgeo.jp
APPLIED TECHNOLOGY CO.,LTD.
MANAGER
Engineering headquarters
Geospatial Information Section
GIS Expert
HIROFUMI HAYASHI
Umeda Center Bldg. 2-4-12 Nakazakinishi
Kitaku, Osaka 530-0015 JAPAN
   Tel: 06-6373-6121
   Fax: 06-6373-6126
More information about the Zoo-psc mailing list
