[ZOO-PSC] Fwd: Re:  ZOO-Project 1.7.0 release
    Angelos Tzotsos
    tzotsos at gmail.com
    Sat Jun  1 04:48:10 PDT 2019
+1
Thank you Gerald.
Angelos
On 6/1/19 12:15 PM, nicolas bozon wrote:
> +1
> Thank you Gérald for this great work
> Best,
> Nick
> Le sam. 1 juin 2019 à 08:20, Massimiliano Cannata <
> massimiliano.cannata at supsi.ch> a écrit :
>> +1
>> Greta Job as always ;-)
>> Il Sab 1 Giu 2019 02:20 Venkatesh Raghavan <raghavan at media.osaka-cu.ac.jp>
>> ha scritto:
>>> +1
>>> Great to see all the new functionality and enhancements in 1.7.0.
>>> Thanks Gerald for managing the release.
>>> Best
>>> Venka
>>> On 6/1/2019 6:53 AM, Jeff McKenna wrote:
>>>> +1
>>>> Great news Gérald.  I will also package 1.7.0 for MS4W users, which I
>>>> see from download statistics is very popular!
>>>> -jeff
>>>> On 2019-05-31 11:33 AM, Gérald Fenoy wrote:
>>>>> Dear PSC members,
>>>>> I would like to ask you to vote for releasing 1.7.0 version of the
>>>>> ZOO-Project.
>>>>> I suppose you have noticed the modifications that has been done over
>>>>> the past few months. One the biggest was to merge prototype-v0 in
>>>>> trunk [1] which was used during almost 2 years for developing the new
>>>>> ZOO-Project version, including for example the R support and the HPC
>>>>> one. Lately, we have made some tests for building for both GNU/Linux
>>>>> [2] and Window [3] platforms using appVeyor free account.
>>>>> Bellow, you can see a list of important modifications:
>>>>>      * Fix issue with UOM definitions in zcfg2sql
>>>>>      * Make callback and HPC support independent from each other
>>>>>      * Update SAGA-GIS support to version 7.2.0
>>>>>      * Add support for custom MapServer style definition for raster
>>> output
>>>>>      * Fix returned bbox definition #170
>>>>>      * Store semaphore status in lenv section for future deletion
>>>>>      * Update Windows support to newer compiler
>>>>>      * Fix issue with UpdateStatus function from the Mono ZOO-API
>>>>>      * Add logging functionality and other utility functions to the C-API
>>>>>      * Return an exception for every output for which nb_pixel or
>>>>>      nb_features is 0
>>>>>      * Add a shared key to the security section to differentiate the
>>>>>      referenced data
>>>>>      * Add MapServer output style definition depending on the geometry
>>>>>      type
>>>>>      * Add ogr.tindex service
>>>>>      * Add support for literaldata input arrays and to call services
>>>>>      asyncrhonously from the JavaScript ZOO-API
>>>>>      * Expose a sleep function to the JavaScript ZOO-API
>>>>>      * Provide FinalizeHPC and FinalizeHPC1 services using scontrol and
>>>>>      sacct respectively
>>>>>      * Store md5sum of the cached file (so, local to the WPS server) to
>>>>>      compare before uploading (if different md5sum) on the HPC server
>>>>>      * Add support for R language
>>>>>      * Add support for using "file://"  for referenced data input
>>>>>      * Add an optional ecookie key for returning third-party cookies
>>>>>      * Fix issue when parsing BoundingBox input #163
>>>>>      * Add memory key to the main section to force the ZOO-Kernel to load
>>>>>      data into memory or use local file
>>>>>      * Add the dialect input to the ogr2ogr service
>>>>>      * Store the list of generated mapfiles in a file (cf DeleteData
>>>>> service)
>>>>>      * Define the correct MS_IMAGEMODE in the generated mapfile
>>>>>      * Option to use MapServer support to publish heatmap
>>>>>      * Add status_code key to the lenv for setting Status HTTP response
>>>>> header
>>>>>      * Add the Creation Option inputs to the Gdal_Dem service
>>>>>      * Add prohibited key in the callback section to define a list of
>>>>>      services not requiring any invocation
>>>>>      * Produce zcfg for OTB applications using the correct default pixel
>>>>> type
>>>>>      * Add asynchronous callback invocation to send information about
>>>>>      the ongoing services to a third-party software
>>>>>      * Add mapsToJson, mapsToJson, and elementsToJson to the API
>>>>>      * Provide a zcfg2sql tool to convert a zcfg metadata file to SQL
>>>>> script
>>>>>      * Add support to store service metadata information into a database
>>>>>      * Add HPC Support for remote execution of SBATCH scripts through
>>> Slurm
>>>>>      * Add cookie reference to _HINTERNET
>>>>>      * Support headers for GET requests from the js ZOO-API
>>>>>      * Pass all headers listed in the attributes parameter from the
>>>>>      [security] section to the hosts listed in the hosts parameter of the
>>>>>      same section (ticket #139)
>>>>> I am proposing myself as a release manager and the release to occur on
>>>>> next Friday (2019/06/07).
>>>>> My vote is obviously +1 for this release.
>>>>> Best regards,
>>>>> [1] http://www.zoo-project.org/trac/changeset/917
>>>>> [2] https://ci.appveyor.com/project/djay/trunk-t67ri/builds/24881108
>>>>> [3] https://ci.appveyor.com/project/djay/trunk-hp3tw/builds/24868734
>>>> _______________________________________________
>>>> Zoo-psc mailing list
>>>> Zoo-psc at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/zoo-psc
Angelos Tzotsos, PhD
Charter Member
Open Source Geospatial Foundation
http://users.ntua.gr/tzotsos
More information about the Zoo-psc
