[ZOO-PSC] [Zoo-discuss] ZOO-Project 1.7.0 release candidate 1
Pablo J. Zader
pzader at gmail.com
Tue Jun 11 20:21:03 PDT 2019
Excelent work!
Congratulations!
El vie., 7 de jun. de 2019 10:02, Gérald Fenoy <gerald.fenoy at geolabs.fr>
escribió:
> Dear all,
> I am glad to announce the new ZOO-Project 1.7.0 release candidate 1
> available at [1].
> This new ZOO-Project release contains new features and fixes, including
> two brand new supports: R language and HPC [2].
> For people familiar with the ZOO-Project the R language will be very easy
> to use for developers willing to develop their services in this language.
> For more information about this new support, please refer to the official
> documentation [3].
> On the other hand, the HPC support is something totally new in the
> ZOO-Project ecosystem. Usually, the ZOO-Kernel is handling the execution of
> a service on its own but, using this HPC support, it is now possible to
> execute asynchronously WPS services using a remote scheduler. This support
> has been implemented to support Slurm as the remote scheduler and the
> communication with the host is made using SSH.
> - Upgrade notes:
> A specific memory parameter has been added to the main.cfg file. With it,
> you can now decide if you want every input data to be loaded in memory or
> to be stored as files. For information about this option, please refer to
> the official documentation[4].
> A specific [metadb] section can be added to the main.cfg file to search
> for WPS Services metadata in a database. For more information about this
> support, please refer to the official documentation [5].
> - New Features and Fixes:
> • Fix issue with UOM definitions in zcfg2sql
> • Make callback and HPC support independent from each other
> • Update SAGA-GIS support to version 7.2.0
> • Add support for custom MapServer style definition for raster
> output
> • Fix returned bbox definition #170
> • Store semaphore status in lenv section for future deletion
> • Update Windows support to newer compiler
> • Fix issue with UpdateStatus function from the Mono ZOO-API
> • Add logging functionality and other utility functions to the
> C-API
> • Return an exception for every output for which nb_pixel or
> nb_features is 0
> • Add a shared key to the security section to differentiate the
> referenced data
> • Add MapServer output style definition depending on the geometry
> type
> • Add ogr.tindex service
> • Add support for literaldata input arrays and to call services
> asyncrhonously from the JavaScript ZOO-API
> • Expose a sleep function to the JavaScript ZOO-API
> • Provide FinalizeHPC and FinalizeHPC1 services using scontrol and
> sacct respectively
> • Store md5sum of the cached file (so, local to the WPS server) to
> compare before uploading (if different md5sum) on the HPC server
> • Add support for R language
> • Add support for using "file://" for referenced data input
> • Add an optional ecookie key for returning third-party cookies
> • Fix issue when parsing BoundingBox? input #163
> • Add memory key to the main section to force the ZOO-Kernel to
> load data into memory or use local file
> • Add the dialect input to the ogr2ogr service
> • Store the list of generated mapfiles in a file (cf DeleteData
> service)
> • Define the correct MS_IMAGEMODE in the generated mapfile
> • Option to use MapServer support to publish heatmap
> • Add status_code key to the lenv for setting Status HTTP response
> header
> • Add the Creation Option inputs to the Gdal_Dem service
> • Add prohibited key in the callback section to define a list of
> services not requiring any invocation
> • Produce zcfg for OTB applications using the correct default
> pixel type
> • Add asynchronous callback invocation to send information about
> the ongoing services to a third-party software
> • Add mapsToJson, mapsToJson, and elementsToJson to the API
> • Provide a zcfg2sql tool to convert a zcfg metadata file to SQL
> script
> • Add support to store service metadata information into a database
> • Add HPC Support for remote execution of SBATCH scripts through
> Slurm
> • Add cookie reference to _HINTERNET
> • Support headers for GET requests from the js ZOO-API
> • Pass all headers listed in the attributes parameter from the
> [security] section to the hosts listed in the hosts parameter of the same
> section (ticket #139)
> Happy testing.
> Thanks a lot for your contribution.
> Best regards,
> Gérald Fenoy
> [1] http://zoo-project.org/new/Code/Download
> [2] http://zoo-project.org/trac/wiki/Release/1.7.0/Notes
> [3] http://zoo-project.org/docs/services/howtos.html#r
> [4] http://zoo-project.org/docs/kernel/configuration.html#main-section
> [5] http://zoo-project.org/docs/kernel/configuration.html#metadb-section
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/zoo-discuss
URL: <http://lists.osgeo.org/pipermail/zoo-psc/attachments/20190612/38fee3a9/attachment.html>
More information about the Zoo-psc
