[ZOO-PSC] ZOO-Project 2.1.0 release proposal
Angelos Tzotsos
tzotsos at gmail.com
Thu Jan 22 00:45:32 PST 2026
Great work!
+1
Angelos
On Thu, Jan 22, 2026 at 10:39 AM Gérald Fenoy via ZOO-PSC <
zoo-psc at lists.osgeo.org> wrote:
> Dear PSC members,
> I take advantage of the date to wish you all a wonderful New Year 2026!
> I come to you today to request your vote on the following motion:
> Releasing a new 2.1.0 version of the ZOO-Project with me as a release
> manager.
> Below is the list of significant changes since version 2.0.0:
> * Add support for the /jobs/{jobId}/results/{outputId} endpoint
> * Force update of the libsodium23 on ubuntu to fix CVE-2025-69277
> * Fix urllib version 2.6.3 to fix CVE-2026-21441, CVE-2025-66418,
> CVE-2025-66471, CVE-2025-50181, CVE-2025-50182
> * Add profiles as per
> https://docs.ogc.org/DRAFTS/18-062r3.html#profile-uris
> * Enhanced storage of metadata embedded within a CWL Application Pachage.
> * Type detection for literal data output for proper result access.
> * Use the cwl2ogc Python library for the transactional support and
> schema definitions for inputs and output.
> * C-API change signature of: printHeaders, printSessionHeaders,
> printAFile, printProcessResponse, printDocument, printRawdataOutput,
> printRawdataOutputs, outputResponse, runGetStatus, invokeCallback,
> setReferenceUrl, printJResult, printJobStatus, printJobList,
> printFilteredJobList, handleDRUError.
> * Introduce the conversion from CWL type to LiteralData in documentation.
> * ZOO-Project-DRU: Bind user to anonymous when no SERVICE_NAMESPACE is
> defined.
> * Add documentation on how to bind a format key to a schema using the
> dedicated schemas section from the configuration file.
> * Support CWL Custom Types with their corresponding format from OGC
> Process
> Description.
> * Support the format key in input/output schema from OGC Process
> Description.
> * Add the CollectionDB.PrimitiveDataFormats table to the database
> containing
> the possible formats key values and CWL Custom types.
> * Change the strcuture of CollectionDB.ows_DataDescription to support a
> format reference (data_format_id).
> * Correct support for BoundingBox format in OGC Process Description.
> * Store the zoofpm ip address in the status database to enable tracking
> which zoofpm pod/container is used to run a process.
> * Update GDAL based services to use the validateVRT for VRT used as
> input file to ensure only the allowed paths are accessible.
> * Add an isAllowedPath function to ensure the URL using file:// give
> access only to the defined allowed paths, defined in the allowedPaths key
> from the main section.
> * Update the skaffold.yaml file for easy deployment of the ZOO-Project
> with DRU and CWL support on a local cluster in different flavors
> * Update the ZOO_DEBUG to use color for messages (if stderr is a tty)
> * Update variables naming, including the main configuration file name
> * Update ZOO_DEBUG function to use LOG_MESSAGE_FORMAT to format the
> debug messages, using the iZooLogLevel integer to decide between: DEBUG,
> INFO, WARN, ERROR, FATAL. Comes with it associated --with-log-format
> option.
> * Store temporary files associated with a run made by an authenticated
> user in a non browsable directory, add a browse service to access these
> files.
> * Remove Miniconda3 from the ZOO-Project-DRU docker image to avoid
> conflict with shared libraries.
> * Add getServicesNamespacePath, printAFile, handlePackage functions to
> the C-API.
> * Add support for "File" inputs in CWL to be identified as ComplexData
> as defined in the Table 3 of the OGC Best Practice for Earth Observation
> Application Package.
> * Add initial support for /processes/{processId}/package as defined in
> the
> OGC API - Processes - Part2: Deploy, Replace, Undeploy draft.
> * Ensure the mutable processes cannot be executed syncrhonously.
> * Ensure that the invokeBasicCallback function is used in case the
> service execution failed.
> * Fix issue when multiple filters are used to filter the jobs list.
> * Add support for x-logo in the info object of the OpenAPI.
> * Add keywords in the process description if any are defined in the
> service metadata.
> * Preserve datatype for literal values that should be passed to the
> cwl runner.
> * Expose complex metada information such as author and contributor
> within the process descrition for OGC API - Processes.
> * Support recording metadata and author for processes deployed from CWL.
> * Add gdalmdiminfo and gdalmdimtranslate services
> * Update support for OGC API - Processes - Part 3: Workflows
> I include my +1 to the upcimng release;
> Best regards,
> Gerald Fenoy
> gerald.fenoy at geolabs.fr
> Chair, ZOO-Project PSC
> ZOO-PSC mailing list
> ZOO-PSC at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/zoo-psc
Angelos Tzotsos, PhD
President, Board of Directors
Open Source Geospatial Foundation
https://www.osgeo.org/member/angelos-tzotsos/
URL: <http://lists.osgeo.org/pipermail/zoo-psc/attachments/20260122/7f6eaf11/attachment.htm>
More information about the ZOO-PSC
