[ZOO-PSC] ZOO-Project 2.1.0 release proposal
Gérald Fenoy
gerald.fenoy at geolabs.fr
Fri Jan 23 00:02:05 PST 2026
Hi all,
Thanks for your quick votes!
I declare the motion accepted and will release 2.1.0 shortly.
Best regards,
> Le 22 janv. 2026 à 15:08, Jeff McKenna via ZOO-PSC <zoo-psc at lists.osgeo.org> a écrit :
> +1 jeff
> (great work!)
> On 2026-01-22 4:29 a.m., Gérald Fenoy via ZOO-PSC wrote:
>> Dear PSC members,
>> I take advantage of the date to wish you all a wonderful New Year 2026!
>> I come to you today to request your vote on the following motion:
>> Releasing a new 2.1.0 version of the ZOO-Project with me as a release manager.
>> Below is the list of significant changes since version 2.0.0:
>> * Add support for the /jobs/{jobId}/results/{outputId} endpoint
>> * Force update of the libsodium23 on ubuntu to fix CVE-2025-69277
>> * Fix urllib version 2.6.3 to fix CVE-2026-21441, CVE-2025-66418,
>> CVE-2025-66471, CVE-2025-50181, CVE-2025-50182
>> * Add profiles as per https://docs.ogc.org/DRAFTS/18-062r3.html#profile-uris
>> * Enhanced storage of metadata embedded within a CWL Application Pachage.
>> * Type detection for literal data output for proper result access.
>> * Use the cwl2ogc Python library for the transactional support and
>> schema definitions for inputs and output.
>> * C-API change signature of: printHeaders, printSessionHeaders,
>> printAFile, printProcessResponse, printDocument, printRawdataOutput,
>> printRawdataOutputs, outputResponse, runGetStatus, invokeCallback,
>> setReferenceUrl, printJResult, printJobStatus, printJobList,
>> printFilteredJobList, handleDRUError.
>> * Introduce the conversion from CWL type to LiteralData in documentation.
>> * ZOO-Project-DRU: Bind user to anonymous when no SERVICE_NAMESPACE is
>> defined.
>> * Add documentation on how to bind a format key to a schema using the
>> dedicated schemas section from the configuration file.
>> * Support CWL Custom Types with their corresponding format from OGC Process
>> Description.
>> * Support the format key in input/output schema from OGC Process Description.
>> * Add the CollectionDB.PrimitiveDataFormats table to the database containing
>> the possible formats key values and CWL Custom types.
>> * Change the strcuture of CollectionDB.ows_DataDescription to support a
>> format reference (data_format_id).
>> * Correct support for BoundingBox format in OGC Process Description.
>> * Store the zoofpm ip address in the status database to enable tracking
>> which zoofpm pod/container is used to run a process.
>> * Update GDAL based services to use the validateVRT for VRT used as
>> input file to ensure only the allowed paths are accessible.
>> * Add an isAllowedPath function to ensure the URL using file:// give
>> access only to the defined allowed paths, defined in the allowedPaths key
>> from the main section.
>> * Update the skaffold.yaml file for easy deployment of the ZOO-Project
>> with DRU and CWL support on a local cluster in different flavors
>> * Update the ZOO_DEBUG to use color for messages (if stderr is a tty)
>> * Update variables naming, including the main configuration file name
>> * Update ZOO_DEBUG function to use LOG_MESSAGE_FORMAT to format the
>> debug messages, using the iZooLogLevel integer to decide between: DEBUG,
>> INFO, WARN, ERROR, FATAL. Comes with it associated --with-log-format option.
>> * Store temporary files associated with a run made by an authenticated
>> user in a non browsable directory, add a browse service to access these
>> files.
>> * Remove Miniconda3 from the ZOO-Project-DRU docker image to avoid
>> conflict with shared libraries.
>> * Add getServicesNamespacePath, printAFile, handlePackage functions to
>> the C-API.
>> * Add support for "File" inputs in CWL to be identified as ComplexData
>> as defined in the Table 3 of the OGC Best Practice for Earth Observation
>> Application Package.
>> * Add initial support for /processes/{processId}/package as defined in the
>> OGC API - Processes - Part2: Deploy, Replace, Undeploy draft.
>> * Ensure the mutable processes cannot be executed syncrhonously.
>> * Ensure that the invokeBasicCallback function is used in case the
>> service execution failed.
>> * Fix issue when multiple filters are used to filter the jobs list.
>> * Add support for x-logo in the info object of the OpenAPI.
>> * Add keywords in the process description if any are defined in the
>> service metadata.
>> * Preserve datatype for literal values that should be passed to the
>> cwl runner.
>> * Expose complex metada information such as author and contributor
>> within the process descrition for OGC API - Processes.
>> * Support recording metadata and author for processes deployed from CWL.
>> * Add gdalmdiminfo and gdalmdimtranslate services
>> * Update support for OGC API - Processes - Part 3: Workflows
>> I include my +1 to the upcimng release;
>> Best regards,
>> Gerald Fenoy
>> Chair, ZOO-Project PSC
> ZOO-PSC mailing list
> ZOO-PSC at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/zoo-psc
Gerald Fenoy
More information about the ZOO-PSC
