[Aust-NZ] Re: [GeoNetwork-devel] Merging new developments into core (was: Finding a way forward)
Simon Pigot sppigot at utas.edu.au
Tue May 20 09:52:50 EDT 2008
Jeroen Ticheler wrote:
> Hi Simon and others,
> I'm reading through the interesting archived discussions you have on
> the aus-nz list (only just subscribed).
>> Up until last month we've fed a lot of the code from the MEST back
>> into the trunk but there is a need to write proposals and get them
>> approved by the community before some of the later changes can be
>> committed. Community approval is a good thing but it takes time to
>> get this together and slot things in to the trunk - that time lag
>> would be a problem for anyone (not just BlueNet) - especially when
>> the priority for us has been features we need.
 > I'm getting quite concerned when I read this, as I feel that putting
such procedures in place should have minimum effect on the normal
development process.
 > What it should do is start some discussion where needed and help to
ensure that not just anything will get into core. Proposals do not have
to be endlessly long
 > either.
 > We need to find a good way of dealing with this, since delaying to
add new developments to core may in the end be the cause of a fork if
your developments
 > deviated to much from trunk. Add to that the fact that you have moved
on to new stuff, it becomes even more likely we'll never see the change
merged back.
They will - we've just been busy since the 2.2 release working on
features/fixes for BlueNet workshops :-). As a protection against not
merging changes back I've made myself post messages to the developers
group giving an overview of what we've been doing at various times.
Those emails were/are placeholders for future proposals.
I think the point of the previous messages in these exchanges (leaving
aside the mildly annoying statements like lack of progress :-)) has been
about forging a more effective community to drive GeoNetwork development
- a first step for that in AU/NZ is to make the BlueNet MEST (with its
embedded AU/NZ specific profiles) available via an svn which leads to....
 > At this point I want to have some discussion on the GeoNetwork
developer list to find a good working solution. The most obvious one for
me is to have
 > sandboxes set up for those that develop new functions. This will
allow a developer to just do his work as normal, but has the big
advantage that others can see
 > what's happening and can be informed on forehand. So when time comes
to merge new code to trunk, we already had a chance to see the code
(through
 > commit mailing list for instance) and the process of a proposal and
voting would be slimmed down a lot.
.....your suggestion of sandboxes as one way of dealing with this - its
a good idea and I've replied to that in a later email on this in which
Roald gave some details about sandboxes elsewhere and asked specific
questions about BlueNet.
Cheers,
Simon
More information about the Aust-NZ mailing list
