[GeoNetwork-devel] [Aust-NZ] Merging new developments into core (was: Finding a way forward)
Simon Pigot sppigot at utas.edu.au
Tue May 20 10:04:30 EDT 2008
Roald de Wit wrote:
> Hi Jeroen et al,
> Jeroen Ticheler wrote:
>> At this point I want to have some discussion on the GeoNetwork
>> developer list to find a good working solution. The most obvious one
>> for me is to have sandboxes set up for those that develop new
>> functions. This will allow a developer to just do his work as normal,
>> but has the big advantage that others can see what's happening and can
>> be informed on forehand. So when time comes to merge new code to
>> trunk, we already had a chance to see the code (through commit mailing
>> list for instance) and the process of a proposal and voting would be
>> slimmed down a lot.
>> Looking forward to some good discussion on this.
> The process you are describing above looks very similar to what happens
> in OpenLayers (not sure if you had this project in mind when writing).
> IMO, having sandboxes is a good thing. Besides what you mention above,
> it makes it easier to collaborate, stay up-to-date with and create
> patches against the trunk. OpenLayers has recently started having an
> add-in system for useful contributions that don't belong to the core
> application. A similar approach could work well with GeoNetwork too, I
> assume.
> If there is approval from the GeoNetwork PSC, how soon could we see
> (amongst others) the BlueNet branch in the GeoNetwork SVN repository
> (maybe as a sandbox to start with)? How does the BlueNet team feel about
> this possible move? Does this sound like the 'wheels' that CSIRO could
> help out greasing (if resources are a problem)?
We've always wanted to hold the BlueNet branch in the geonetwork svn but
have been a bit hesitant to add to the admin load of the geonetwork svn
admins*.
I don't see any delay in doing this - especially as I'd already offered
the code in response to the original collaboration proposal by Cameron -
its always been possible the problem has been finding a nice way to do it.
Naturally I'd need to refresh BlueNet management on this but its
something we've often spoken of as a preferred option.
Cheers,
Simon
* - Instead we'd been looking at setting up access to an svn at bluenet
- using svk to mirror the trunk and having the bluenet code as a branch.
This seemed to work fine in testing as long as the trunk and the branch
don't get too far out of sync - but we've never made the svn (used by
svk) available - other priorities and concern about competing/confusing
svns has meant that it didn't happen. Sounds like this idea can quietly
drop off the twig....:-)
More information about the Aust-NZ mailing list
