Fw: [Aust-NZ] Finding a way forward - GeoNetwork as platform to support ANZLIC Profile of ISO 19115/19139
Rob Atkinson robatkinson101 at gmail.com
Tue May 20 20:35:34 EDT 2008
As a long term participant in OGC, I think it is capable of providing A
computational view of a reference architecture.
We may want to support parallel views - for example a registry can easily
support CSW. ebXML, Z39.50, SPARL, OAI etc interfaces from the same content.
This "profiling pattern" is possibly within the OGC purview, but its not
handled well at the moment IMHO because its something that affects
deployers, not technology developers: the need to maintain a consistent
_information architecture_. OGC is a technology vendor association
primarily.
GSDI could own a SDI reference architecture - but doesnt seem geared up for
it.
OSGEO should at least consider the commonality between its projects, out of
business sense. If databases and services and clients and registries dont
handle common metadata, the pieces dont fit together well. Every time I get
asked to advise someone on building tools I have to warn them they have a
huge job gluing the pieces together into a coherent whole, and there will
huge amounts of redundant information scattered across the configurations of
each component that will make it all expensive to build, test and maintain.
Proprietary systems do tend to be better at this, since inter-component
interoperation is often the key to marketing success. Peopele want an
application - and they buy all the components with the expectation the
application will work. IMHO OSGEO could significantly improve its offerings
by having a common information architecture (without necessarily mandating
all projects use it).
2c, but with inflation $64million :-)
Rob
On Wed, May 21, 2008 at 9:55 AM, <Bruce.Bannerman at dpi.vic.gov.au> wrote:
> IMO:
> Thanks for the comments Rob,
> (Can all people please ensure that the OSGeo-AustNZ list is included in
> replies, I'd like to keep the list as the archive record for this thread?)
> Agreed, a branch is not ideal for the medium to long term.
> Ideally from these discussions we'll get the momentum to establish the
> mechanism whereby metadata profiles can be configured as 'plugins' to the
> stable GeoNetwork version that is current at that point in time.
> Until this occurs, we have to find a better way of collaborating to
> ensuring a consistent, quality approach. What we are doing now is not
> working and resulting in duplicated effort. Therefore, I'd like to see all
> proposals explored and a preferred way forward agreed on.
> wrt 'Reference Architecture', I can't speak for others, however:
> - I don't think that this is a space that OSGeo would want to get into.
> - I wouldn't want to be prescriptive on what the projects can and can't do.
> We are talking about projects that thrive on innovation.
> - I think that this is a role that is more appropriately handled by the
> OGC, in this instance with the CSW standard. As I understand it, GeoNetwork
> already supports CSW (excluding support for ebRIM functionality).
> Jeroen may wish to comment further on the GeoNetwork communities thoughts
> and intentions here.
> Bruce Bannerman
>  *"Rob Atkinson" <robatkinson101 at gmail.com>*
> 21/05/2008 09:14 AM
>   To
>  cc
> ozmeta-l at erin.gov.au, asdi-l at lists.anzlic.org.au, info at osdm.gov.au
> Subject
> Re: Fw: [Aust-NZ] Finding a way forward - GeoNetwork as platform to support
> We should not be looking at a branch - there is nothing wierd about the
> ANZLIC profile.
> Geonetwork needs to be capable of being configured with a profile of a
> baseline standard it supports (ISO 19115 in this case) - this is _THE_ basic
> metadata implementation pattern. Putting the key piece of core configuration
> capability required onto a branch is rather non-sensical.
> in fact, all tiers of an OS SDI reference implementatiuon (tools and
> architecture) need to follow the pattern - this is the goal of the SISS
> project.
> FYI. I'm currently drawing up some architecture ideas for this, on behalf
> of the SISS project. This is a somewhat slow process as I have a day a week
> assigned to this and i'm doing a little geoserver effort support at the same
> time.
> The broader challenge of how we effectively share architectural patterns is
> also a concern - we design by starting from scratch, or "clone and modify"
> from existing designs, and wonder why we have difficulty joining the bits
> back together once built. Is there a role for a "reference architecture" for
> OSGEO?
> Regards
> Rob Atkinson
> On Tue, May 20, 2008 at 8:34 PM, <*Bruce.Bannerman at dpi.vic.gov.au*<Bruce.Bannerman at dpi.vic.gov.au>>
> wrote:
> IMO:
> This is a resend for people who are not following the thread on the
> OSGeo-AustNZ list.
> Bruce Bannerman
> ----- Forwarded by Bruce Bannerman/DPI/VICGOV1 on 20/05/08 08:21 PM -----
> *Bruce Bannerman <**bruce at bannerman.id.au* <bruce at bannerman.id.au>*>*
> Sent by: *aust-nz-bounces at lists.osgeo.org*<aust-nz-bounces at lists.osgeo.org>
> 20/05/08 08:19 PM
>   To
> *aust-nz at lists.osgeo.org* <aust-nz at lists.osgeo.org>, *
> anzlicmet-l at listserv.its.utas.edu.au*<anzlicmet-l at listserv.its.utas.edu.au>
> cc
>   Subject
> Re: [Aust-NZ] Finding a way forward - GeoNetwork as platform to
> Thank you to all who have responded so far.
> We're starting to get a snapshot of open source spatial work that is
> going on around Australia and New Zealand. It is certainly starting to
> take off.
> Please keep the comments coming, so that we as a community get a better
> understanding of the issues involved.
> I would like to reiterate that this email thread is not intended as a
> criticism of any group or individual.
> While I had originally wondered what we, as a community, could do to
> support Simon with the GeoNetwork ANZLIC Profile work, I can see that it
> is rapidly turning into:
> How can we support Simon, Byron, Cameron, Robert and a number of other
> organisations in their GeoNetwork ANZLIC Profile work?
> We have the beginnings of an open source community. Where to from here?
> What we eventually put in place could have potential for other
> Australian and New Zealand specific open source spatial work in the
> future.
> I'd also like to hear some thoughts from some of our more experienced
> open source developers.
> To kick things off:
> I've had an off line email from Jeroen Ticheler from the GeoNetwork
> community. Jeroen is keen to help us where he can.
> He has suggested that if it is required, it may be possible establish a
> branch with ANZLIC support on the Geonetwork SubVersion.
> Please keep the comments coming. This is very informative.
> Bruce Bannerman
> Aust-NZ mailing list*
> **Aust-NZ at lists.osgeo.org* <Aust-NZ at lists.osgeo.org>*
> **http://lists.osgeo.org/mailman/listinfo/aust-nz*<http://lists.osgeo.org/mailman/listinfo/aust-nz>
> Notice:
> This email and any attachments may contain information that is personal,
> confidential,
> legally privileged and/or copyright. No part of it should be reproduced,
> adapted or communicated without the prior written consent of the copyright
> owner.
> It is the responsibility of the recipient to check for and remove viruses.
> If you have received this email in error, please notify the sender by
> return email, delete it from your system and destroy any copies. You are not
> authorised to use, communicate or rely on the information contained in this
> email.
> Please consider the environment before printing this email.
URL: http://lists.osgeo.org/pipermail/aust-nz/attachments/20080521/f63e8d95/attachment-0001.html
More information about the Aust-NZ mailing list
