FW: Fwd: FW: [Aust-NZ] Time to move - Incorporation
ofOSGeo-AustNZ] [SEC=UNCLASSIFIED]
Bruce Bannerman
bruce.bannerman.osgeo at gmail.com
Thu Oct 16 21:17:31 EDT 2008
This is the option that we have the legal advice for.
As such we should continue what we originally agreed on and incorporate in
WA.
(Brent, thanks for the attractive alternative. Let's keep it for plan B, in
case something else goes wrong).
Tim,
I'm glad that you're back and have the time to contribute.
I'm now passing this back to you to resolve.
Bruce
On Fri, Oct 17, 2008 at 11:54 AM, Bruce Bannerman <B.Bannerman at bom.gov.au>wrote:
> > The incorporated association gives the same limited liability
> > as Pty Ltd does. It is designed as a cheaper method of
> > achieving the same ends but is restricted to non profits. It
> > exists for a reason, and I think we should use it.
> > I'll dig out what I started for going down this path wrt WA
> > incorporation as that seemed to provide the most flexibility
> > at minimal cost. After that we only need to register with
> > ASIC to operate nationally.
> > Regards,
> > Tim Bowden
URL: http://lists.osgeo.org/pipermail/aust-nz/attachments/20081017/d7cf1717/attachment.html
More information about the Aust-NZ
