[Aust-NZ] qGIS - Nearmap Support
Jonathan Nagy jnagy.82 at gmail.com
Thu Nov 11 22:24:41 EST 2010
(sorry, i didnt finish see changes below.)
- any information derived from using the service (ie. research) is owned by
you, and distribution of that information must be under a CC-BY-SA license
(see http://creativecommons.org/licenses/by-sa/3.0/).
Even if your use was classified as commercial, the only restrictions that
are added are that you don't exceed 100,000 tiles a month, or compete with
the organization (paraphrasing).
Regardless of what I perceive the 'rules' to be, you should still have a
read of the terms yourself.  Its a pretty light read compared to *some* license
agreements.
-Jon
On Fri, Nov 12, 2010 at 2:14 PM, Jonathan Nagy <jnagy.82 at gmail.com> wrote:
> I believe academic use would be classified as non-commercial, and would
> therefore fall under the Free / Personal Community license (see here
> http://www.nearmap.com/products/community-licence).
> The 'Free / Personal Community' license must be adhered to by the
> following:
> On Fri, Nov 12, 2010 at 1:39 PM, Francis Markham <fmarkham at gmail.com>wrote:
>> Great work Jonathon.  I was wondering if anyone knows about the licensing
>> terms of nearmap in an academic / research context?
>> Cheers,
>> Francis Markham
>> On 12 November 2010 12:54, Jonathan Nagy <jnagy.82 at gmail.com> wrote:
>>> If anyone out there is a qGIS user or dabbler, I've forked the openlayers
>>> plugin that allows Google / Yahoo / OSM to be used as a backdrop layer.
>>> For those of you that don't know, Nearmap is a source of recently
>>> acquired high resolution Australian imagery with lax licensing requirements.
>>>  My changes to the openlayers plugin include the ability to use
>>> Nearmap.com's growing imagery source as a backdrop layer within qGIS.
>>> Until the original author pulls in my changes, you can download the
>>> plugin and install it from here:
>>> https://github.com/TheGeoist/qgis-openlayers-plugin
>>> *Note: you must operate within the 900913 projection, with on-the-fly
>>> transformations.*
>>> Comments are welcome from those of you who can appreciate it.
>>>  - Jonathan
>>> Aust-NZ mailing list
>>> Aust-NZ at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/aust-nz
URL: http://lists.osgeo.org/pipermail/aust-nz/attachments/20101112/0882978a/attachment-0001.html
More information about the Aust-NZ mailing list
