[Aust-NZ] Importing records from GeoNetwork => BlueNet MEST
jforne jforne at linz.govt.nz
Thu Nov 3 20:30:21 EDT 2011
Hi there
Could someone please give me a layman's explanation why I can insert (via copy/paste) the attached record into GeoNetwork (v2.4.3 0) - but not into BlueNet MEST (v1.4.6) (I've attached the error message I get)?
Please note that the attached metadata file was created using GeoNetwork (v 2.6.4).
Thanks in anticipation,
John
[cid:010313923 at 03112011-01FF]
This message contains information, which is confidential and may be subject to legal privilege.
If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message.
If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message.
LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ.
Thank You.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Importing-records-from-GeoNetwork-BlueNet-MEST-tp6961270p6961270.html
Sent from the OSGeo Australia - New Zealand Local Chapter mailing list archive at Nabble.com.
More information about the Aust-NZ mailing list
