[Aust-NZ] Importing records from GeoNetwork => BlueNet MEST
Simon.Pigot at csiro.au
Thu Nov 3 20:52:34 EDT 2011
John,
I can import or copy/paste that record into my BlueNetMEST installation here successfully.
It looks to me from the message that your installation might be missing a jar file - can you check and see whether the jar file WEB-INF/lib/mime-util-2.1.2.jar is present in your BlueNetMEST installation?
It is part of the installation so I have no idea why yours appears to have gone missing (its probably been manually removed or ....???).
In any case if you need that jar let me know and I'll send it to you or you can copy it from another installation of GeoNetwork or the BlueNetMEST into WEB-INF/lib.
Cheers,
Simon
________________________________________
From: aust-nz-bounces at lists.osgeo.org [aust-nz-bounces at lists.osgeo.org] On Behalf Of jforne [jforne at linz.govt.nz]
Sent: Friday, 4 November 2011 11:30 AM
To: aust-nz at lists.osgeo.org
Subject: [Aust-NZ] Importing records from GeoNetwork => BlueNet MEST
Hi there
Could someone please give me a layman's explanation why I can insert (via copy/paste) the attached record into GeoNetwork (v2.4.3 0) - but not into BlueNet MEST (v1.4.6) (I've attached the error message I get)?
Please note that the attached metadata file was created using GeoNetwork (v 2.6.4).
Thanks in anticipation,
John
[cid:010313923 at 03112011-01FF]
This message contains information, which is confidential and may be subject to legal privilege.
If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message.
If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message.
LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ.
Thank You.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Importing-records-from-GeoNetwork-BlueNet-MEST-tp6961270p6961270.html
Sent from the OSGeo Australia - New Zealand Local Chapter mailing list archive at Nabble.com.
Aust-NZ mailing list
Aust-NZ at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/aust-nz
More information about the Aust-NZ
