[Aust-NZ] ANZLIC template for GeoNetwork?
John Brisbin john at boab.info
Sun Nov 13 17:00:24 EST 2011
Thanks so much Byron...that's very helpful information. I'll stop
fretting for the moment and look forward to the 2.8 upgrade!
Re: It's a pity I'll miss that meeting in person, but am scheduled to
present a bit of our story to the group by teleconf in about 30 mins.
Kind regards.
JB
On 14/11/2011 3:54 AM, Byron wrote:
> Hi John,
> The answer to your question is that what you are asking for is nearly
> there.
> Plugin Schema support has been a priority in the GeoNetwork 2.7 - 2.8
> release. The latest builds of 2.7 do have support for the ANZLIC
> profile, but it is not quite production ready.  I would recommend
> waiting a couple of months for the production release (2.8) but you
> can download and build the 2.7 version to check it out at -
> http://geonetwork.svn.sourceforge.net/viewvc/geonetwork/trunk. To use
> the plugin schemas you will also need to down load the schema
> repository at
> http://geonetwork.svn.sourceforge.net/viewvc/geonetwork/schemas.
> Note: to load the ANZLIC Schema you will need to name it
> iso19139.anzlic in the "Add metadata schema/profile" administration
> gui, and then browse to the zipped file  in your just built schemas
> directory called iso19139.anzlic.zip. Be sure to add the templates for
> the profile after this.
> Also, you may want to check out the new alternative user interface
> that you can enable in the config-gui file.
> You may be aware of the GeoNetwork User Group meeting taking place
> today and tomorrow in Canberra. Your questions will be answered there.
> Look for documentation of this conference appearing soon. Simon Pigot,
> who is a core GeoNetwork developer is heavily involved in this meeting
> and will be shedding some light on precisely these questions you ask.
> Cheers,
> Byron Cochrane
> LISAsoft
> On 12/11/2011, at 11:35 PM, John Brisbin wrote:
>> G'Day all,
>> Sorry for a vaguish sort of question, but the issue of an
>> ASDD-compliant metadata template has finally swum into my vision with
>> some clarity.
>> Like many others, we were initially set up with a default GeoNetwork
>> install and have been merrily entering records using the iso19139
>> template.
>> We've been asked to look at the potential to contribute as an ASDD
>> node, and now realise we probably should have been using a different
>> template all along.
>> In the GeoNetwork admin interface there's an alluring [Add Templates]
>> link: I am (perhaps optimistically) wanting to simply click and
>> upload the ASDD-compliant template.
>> So: I've just been prowling through the ASDD site and others looking
>> for a silver bullet: the [download ASDD template] link...to no avail.
>> Is there such a thing, or is this a conceptual misunderstanding, or
>> is this like asking what gravity looks like?
>> URLs, RTFMs, and other pointers happily received!
>> Thanks indeed,
>> JB
>> John Brisbin
>> Managing Director, BoaB interactive Pty Ltd
>> POB 802 Townsville, QLD 4810
>> M: 0407 471 565 | P: 07 3103 0574
>> Skype: boabjohn | Twitter: @boabjohn
>> Aust-NZ mailing list
>> Aust-NZ at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/aust-nz
John Brisbin
More information about the Aust-NZ mailing list
