[Aust-NZ] NSW Government Procurement actively discourages use of Open Source
Peter Barrs peter.barrs at data-arterial.net
Tue Nov 18 13:45:16 PST 2014
+1
Cameron, I hope you are able to obtain a rationale from NSW Finance -
presumably it relates to 23.2 a/b, which in themselves are not
inhibitory of open source.
As previously remarked, it seems a degree of ignorance is apparent.
Peter Barrs
Data Arterial Pty Ltd
On 19/11/2014 5:53 AM, Cameron Shorter wrote:
> OSGeo Aust-NZ,
> During a recent NSW tendering process (for a spatial software system),
> we have discovered that NSW Government purchasing guidelines actively
> discourage use of Open Source Software.
> I propose that the following email is sent on behalf of OSGeo Aust/NZ.
> Any comments, votes for or against?
> Vote from me: +1 Cameron Shorter
> From: President of the Open Source Geospatial Foundation -
> Australian/New Zealand Chapter
> To: nswbuy at finance.nsw.gov.au
> CC: Aust-NZ at lists.osgeo.org
> To NSW Procurement Team,
> We, the Australian and New Zealand chapter of the Open Source
> Geospatial Foundation, are concerned that NSW Procurement guidelines
> about Open Source Software should be changed.
> The guidelines:
> * Inaccurately imply Proprietary Software is less risky than Open
> Source [1],
> * Unfairly discriminate against Australian Open Source Software
> solutions and businesses [1],
> * Conflict with Australian government policy which directly mandate
> that Open Source and Proprietary Software should be considered
> equally. [2]
> * Increases the cost of NSW Government IT purchases by actively
> discouraging use of Open Source.
> Could the NSW Procurement Team please review the current Open Source
> statement, assess the appropriateness of updating to Australian
> Government Policy statements related to Open Source, and respond with
> your assessment.
> *Reference 1:*
> The NSW IT procurement framework (version 3.1) specifically discourses
> use of Open Source software with Major Project System Integration
> Services.
> /23 Open Source Software //
> //23.1 The Contractor must ensure that: //
> //(a) none of the Deliverables comprise Open Source Software; and //
> //(b) it does not insert any Open Source Software into the Customer
> Environment, except to the extent otherwise approved by the Customer
> in writing. //
> //23.2 Where the Customer gives its approval in relation to the use of
> any Open Source Software //
> //under clause 23.1: //
> //(a) the Contractor must ensure that the use of that Open Source
> Software will not result in an obligation to disclose, license or
> otherwise make available any part of the Customer Environment or any
> of the Customer’sConfidential Information to any third party; and //
> //(b) the use of that Open Source Software will not in any way
> diminish the Contractor’s obligations under the Contract, including
> without limitation in relation to any warranties, indemnities or any
> provisions dealing with the licensing or assignment of Intellectual
> Property. /
> https://www.procurepoint.nsw.gov.au/before-you-supply/standard-procurement-contract-templates/procure-it-framework-version-31
> See:  Module 13A Major project systems integration services
> *Reference 2:*
> Australian Government Policy on Open Source Software:
> /Principle 1: Australian Government ICT procurement processes must
> actively and fairly consider all types of available software.//
> //Australian Government agencies must actively and fairly consider all
> types of available software (including but not limited to open source
> software and proprietary software) through their ICT procurement
> processes. It is recognised there may be areas where open source
> software is not yet available for consideration. Procurement decisions
> must be made based on value for money. Procurement decisions should
> take into account //
> //whole-of-life costs, capability, security, scalability,
> transferability, support and manageability requirements.//
> //For a covered procurement (over $80K), agencies are required to
> include in their procurement plan that open source software will be
> considered equally alongside proprietary software. Agencies will be
> required to insert a statement into any Request for Tender that they
> will consider open source software equally alongside proprietary
> software. Tender responses will be evaluated under the normal
> requirements of the Commonwealth Procurement Guidelines. For a
> non-covered procurement (below $80K), agencies are required to
> document all key decisions, as required by the Commonwealth
> Procurement Guidelines. This includes how they considered open source
> software suppliers when selecting suppliers to respond to the Select
> Tender or Request for Quotation.//
> Australian Government Policy on Open Source Software,
> http://www.finance.gov.au/policy-guides-procurement/open-source-software/
> Cameron Shorter,
> Software and Data Solutions Manager
> LISAsoft
> Suite 112, Jones Bay Wharf,
> 26 - 32 Pirrama Rd, Pyrmont NSW 2009
> P +61 2 9009 5000,  Wwww.lisasoft.com,  F +61 2 9009 5099
> Aust-NZ mailing list
> http://lists.osgeo.org/mailman/listinfo/aust-nz
URL: <http://lists.osgeo.org/pipermail/aust-nz/attachments/20141119/55efc0a8/attachment.html>
More information about the Aust-NZ mailing list
