[OSGeo-Discuss] Research For Shared Java CRS Library
Justin Deoliveira jdeolive at openplans.org
Mon May 5 13:19:58 PDT 2008
> I know some of you want to know why we aren’t just going to use the
> GeoAPI interfaces. I don’t know enough about the GeoAPI code to say that
> it won’t be used. I think that will need to be part of our research
> process. It would make sense to use GeoAPI as a home for common
> interfaces if this is possible. I don’t want to reinvent any existing
> technology.
Just to chime in about GeoAPI. From someone who has had to implement a
number of its interfaces here are my thoughts.
1) Its a great way to talk about standards in the context of java interfaces
2) Its not a good way to promote interoperability
Now this is just my opinion of course so take it with a grain of salt.
But anyone who has looked at the geoapi interfaces can tell you they are
not simple. Which creates a large entry barrier for someone wanting to
implement them, which defeats the entire purpose.
I would think by definition a library which is intended to be used as a
base for other projects needs to be as simple as possible. Look at proj
for instance, i am by no means an expert on the code base but from what
I have seen there are no unnecessary abstractions. Which I would think
is a large part of the reason it has been utilized so effectively by
most of the other projects in the C and python community.
My 2c.
-Justin
> Landon
> P.S. – I have subscribed to the MetaCRS mailing list. I will post
> messages there about any decisions made on sharing
> “programming-language-independent” (PLI) resources like CRS definitions
> or test cases.
> *Warning:
> *Information provided via electronic media is not guaranteed against
> defects including translation and transmission errors. If the reader is
> not the intended recipient, you are hereby notified that any
> dissemination, distribution or copying of this communication is strictly
> prohibited.  If you have received this information in error, please
> notify the sender immediately. !DSPAM:4007,481f601c109671628642973!
> Discuss mailing list
> Discuss at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/discuss
Justin Deoliveira
The Open Planning Project
More information about the Discuss mailing list
