[OSGeo-Discuss] XML to GML XSLT
"René A. Enguehard" ahugenerd at gmail.com
Wed Jun 10 13:59:15 EDT 2009
Hi all,
I've been working on getting an XML document to transform into a GML
document. Currently I'm running into two issues:
1. How do we define the XSD rules for a string node with an attribute?
ie: <point dimension="2">12.12, 34.34</point>
    Currently all I have found relates to simple text nodes or simple
attribute nodes, but not mixed ones.
2. How do we get XSD to "play nice" with the gml: prefix? I want to use
gml:Point and gml:pos but the XSD file doesn't validate.
Some sample XML:
<user xmlns:gml="http://www.opengis.net/gml">
        <gml:pos dimension="2">-97.7452090, 30.2687350</gml:pos>
The XSD file for the code (so far):
<?xml version="1.0" encoding="utf-8"?>
    <xsd:import namespace="http://www.opengis.net/gml"/>
    <xsd:element name="user" type="userType" />
    <xsd:complexType name="userType">
            <xsd:element name="name" type="xsd:string" />
            <xsd:element name="gml:Point" type="gml:Point" />    <---- ???
Thanks for your help,
René A. Enguehard
More information about the Discuss mailing list
