[OSGeo-Discuss] Comparision between MapServer/OpenLayers and ESRI
ArcIMS
P Kishor
punk.kish at gmail.com
Wed May 27 00:48:22 EDT 2009
On Wed, May 27, 2009 at 8:38 AM, John Callahan <john.callahan at udel.edu> wrote:
> I've dealt with this question before but not quite with those specifics.
> Actually, I've had these issues from a different angle: people who already
> have the ESRI suite because their larger company or government agency
> purchased an ESRI enterprise license yet they were looking at open source as
> a serious option.
> Hopefully some of this can help...
> My first thought is that a current ESRI solution would be based on ArcGIS
> Server rather than ArcIMS. ArcIMS is basically gone (the 2008 Dev Summit
> had ZERO tech sessions on ArcIMS but did have a few migration to ArcGIS
> server topics. On the current ESRI support site for ArcIMS life cycle, they
> do NOT mention a 9.4 release (current is 9.3.1) although they do for ArcGIS
> Desktop and ArcGIS Server. The ArcIMS Data Delivery Extension is not being
> sold any more. ArcIMS could do basic clip-n-ship using the Extract Server
> but that is only available using the old AXL image services and NOT the
> ArcMap services. I've heard trusted rumors (from some ESRI staff at tech
> shows and conferences) that ArcGIS Server is where ESRI has been putting all
> their energy for the past few years.
> ArcGIS Server (AGS) costs quite a bit, up to 4 cores it's about $32K - $40K
> per server for the advanced, enterprise level. This Advanced version
> includes the 3D, Spatial, Network and Geostatistical extenions. It does not
> include the Data Interoperability extension (based on FME Safe and typically
> used for data ETL tasks) or the Image Server extension (used for real-time
> display of rasters in various bands and combinations, like NDVI)
> Extensions are about 4K - 8K each.
> The "Enterprise" licenses mean it includes more features plus ArcSDE for
> major RDBMS like Oracle SQL Server. The "Workgroup" version includes a
> limited ArcSDE for Workgroups. Enterprise ArcSDE (and therefore Enterprise
> ArcGIS Server) is almost *required* for anything data delivery system
> greater than a few GB and especially if web based.
> For more pricing, here are a few I found...
> https://www.gsaadvantage.gov/ (search for "arcgis server")
> http://www.eyaktek.com/public/ESRI%20Catalog%2006-20-08.xls
> http://www.esri.com/partners/hardware/ibm-advanced-enterprise.pdf
> For data processing and delivery, like LIDAR processing and anything that
> would result from a model, is typically done either 1) via Model Builder,
> python scripts in the ArcMap MXD document (typically unstable), or 2) via
> ArcObjects coding through the NET or Java APIs (the Interface OO programming
> is difficult to learn). Recently, quite a lot is done through ArcGIS
> Desktop (ArcMap.) ArcCatalog is used to fully manage AGS. There is a web
> application for managing AGS but it can't do everything that ArcCatalog can
> do, critical things like map caching. (at least that was the case in 9.2.)
> So, yes, you'll need quite a few ArcGIS Desktops.
> You'll need ArcEditor (~$5K) versions for writing to ArcSDE. You'll need
> ArcInfo level (~$14K) for creating the models to be processed in AGS. This
> does not include desktop extensions which run about $2.5K each. Plus, many
> advanced feature of AGS (that you see in demos or brochures) are only
> accessible via thick AGS clients like ArcGIS DEsktop or ArcGIS Explorer.
> Remember the initial primary purpose for AGS was was a desktop GIS server,
> like a replacement for the old ArcInfo 7x geoprocessing server. It was to
> push centralized GIS processing, editing, mobile checkin/checkout,
> geocoding, etc... Traditional web applications (replacement for ArcIMS)
> came later.
This is a most excellent summary John. Consider adding this to a wiki
page that can be regularly updated.
> - John
> John Callahan
> Geospatial Application Developer
> Delaware Geological Survey, University of Delaware
> 227 Academy St, Newark DE 19716-7501
> Tel: (302) 831-3584 Email: john.callahan at udel.edu
> http://www.dgs.udel.edu
> Bill Thoen wrote:
>> I need to make a case for developing a map and data server using Open
>> Source software such as MapServer, Open Layers, PostgereSQL/PostGIS to
>> counter a proposal to go with ESRI's solutions. The client who this would
>> be directed to manages a lot of land parcels on which some development is
>> planned. As part of the support for this, the object is to build an
>> Internet-accessible server that maintains about 800Gb of spatial and
>> tabular data, that can provide interactive maps of the properties, data
>> downloads of selected areas and layers in shapefile, AutoCAD and other
>> formats. It also needs to generate 3D surfaces from dense LiDAR data that's
>> available. It also needs a database cataloging system that can be searched
>> for data held in the system. Finally, it needs to provide different access
>> privileges to various personnel who will be using restricted data sets.
>> So what I need are some *current* facts about what packages are needed to
>> do this completely with ESRI software and what it will cost. Have any of
>> you had to address this 800-lb gorilla problem recently and do you have any
>> advice or facts I can use? I have to present my case to people who don't
>> know much about GIS so I think price is going to be my best argument. So
>> far, all I've been able to ascertain is that an Internet license for ArcIMS
>> costs about $9 - $10K per dual core machine per year. Is that true? And
>> don't you also need ArcSDE for the database connection, and some Arc3D for
>> surface generation from LiDAR and copies of ArcGIS all around, and is data
>> downloading even available through ArcIMS? What functionality comes
>> "out-of-the-box" with ESRI's tools that meets what I've listed above? Is
>> there something in the ESRI stable that can maintain differential,
>> password-protected user access? How much would still have to be developed?
>> And what about training and staff to maintain the system? What's that cost?
>> If anyone has answers to any of these questions I'd be grateful if you
>> could give me some facts. As it stands I can put those questions out for
>> consideration, but I'd like to know the answers too.
>> Thanks,
>> - Bill Thoen
>> Discuss mailing list
>> Discuss at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/discuss
Puneet Kishor http://www.punkish.org/
Carbon Model http://carbonmodel.org/
Charter Member, Open Source Geospatial Foundation http://www.osgeo.org/
Science Commons Fellow, Geospatial Data http://sciencecommons.org
Nelson Institute, UW-Madison http://www.nelson.wisc.edu/
collaborate, communicate, compete
More information about the Discuss
