[OSGeo-Discuss] mxd to other format (i.e. shapefile)
George Silva
georger.silva at gmail.com
Mon Aug 2 22:25:02 EDT 2010
You must be confusing things here Maning,
Mxd is the format that ArcGIS uses to store *mapdocuments*, while
shapefiles/database geometry data/coverages/rasters are displayed on that
map. If you only have the mxd you won't be able to convert anything to
shapefile. You need the original data.
A Mxd is much like an HTML. It provides information on how content is
organized, but it's not content itself.
George
On Mon, Aug 2, 2010 at 11:21 PM, maning sambale
<emmanuel.sambale at gmail.com>wrote:
> No luck so far looking for a converter.
> Basically, I want to export geometry and attributes without the
> styling from an Arc's mxd format to shapefile.
> Any workaround here (other then looking for an ArcGIS installed machine)?
> cheers,
> maning
> "Freedom is still the most radical idea of all" -N.Branden
> wiki: http://esambale.wikispaces.com/
> blog: http://epsg4253.wordpress.com/
> Discuss mailing list
> Discuss at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/discuss
George R. C. Silva
Desenvolvimento em GIS
http://blog.geoprocessamento.net
URL: http://lists.osgeo.org/pipermail/discuss/attachments/20100802/655b8779/attachment.html
More information about the Discuss
