[OSGeo-Discuss] mxd to other format (i.e. shapefile)
maning sambale
emmanuel.sambale at gmail.com
Mon Aug 2 22:46:47 EDT 2010
George,
To get this right, mxd are actually just a styling file similar to
Arcview's apr and avl?
On Tue, Aug 3, 2010 at 10:25 AM, George Silva <georger.silva at gmail.com> wrote:
> You must be confusing things here Maning,
> Mxd is the format that ArcGIS uses to store mapdocuments, while
> shapefiles/database geometry data/coverages/rasters are displayed on that
> map. If you only have the mxd you won't be able to convert anything to
> shapefile. You need the original data.
> A Mxd is much like an HTML. It provides information on how content is
> organized, but it's not content itself.
> George
> On Mon, Aug 2, 2010 at 11:21 PM, maning sambale <emmanuel.sambale at gmail.com>
> wrote:
>> No luck so far looking for a converter.
>> Basically, I want to export geometry and attributes without the
>> styling from an Arc's mxd format to shapefile.
>> Any workaround here (other then looking for an ArcGIS installed machine)?
>> cheers,
>> maning
>> "Freedom is still the most radical idea of all" -N.Branden
>> wiki: http://esambale.wikispaces.com/
>> blog: http://epsg4253.wordpress.com/
>> Discuss mailing list
>> Discuss at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/discuss
> George R. C. Silva
> Desenvolvimento em GIS
> http://blog.geoprocessamento.net
cheers,
maning
More information about the Discuss
