[OSGeo-Discuss] Re: Automatic-Metadata Catalogueing
Bracco Stefano
Stefano.Bracco at eurac.edu
Wed Aug 25 03:49:01 EDT 2010
Hi Martin,
May ask you if thepython script you mention is available for download
somewhere?
Thanks a lot in advance for the information.
Stefano
-----Original Message-----
[mailto:discuss-bounces at lists.osgeo.org] On Behalf Of Martin Seiler
Sent: Tuesday, 24 August, 2010 13:40
To: OSGeo Discussions
Subject: Re: [OSGeo-Discuss] Re: Automatic-Metadata Catalogueing
> I found two solutions:
> * SpatialDataCataloguingScript at
> http://code.google.com/p/spatialguru/wiki/SpatialDataCataloguingScript
> => this works well after some fixing.
> But how do I best use the generated XML file?
> Apparently, gvSIG has some tool as well:
> Semi-automatic Metadata Extraction from Imagery and Cartographic data
> http://www.geoinfo.uji.es/pubs/igarss07-metadata-cameraready.pdf
You also might want to take a look at CatMDEdit [1].
Not too long ago I did a survey on Metadata-Editors regarding their
ability to extract metadata in a semi-automatic manner. It seems to be
a widely neglected field, with a lot of potential...
CatMDEdit was the most useful editor that I've tested, but in the end it
didn't fulfill the requirements. I also ended up writing python scripts
that make use of gdal/ogr, creating ISO- and INSPIRE-complaint metadata
sets.
Ciao,
Martin
[1] http://forge.osor.eu/projects/catmdedit/
Discuss mailing list
Discuss at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/discuss
More information about the Discuss
