[OSGeo-Discuss] Working with shapefiles in PHP
Noli Sicad
nsicad at gmail.com
Sun Aug 29 11:10:58 EDT 2010
> MapServer does too. Just use the AGG driver in the OUTPUTFORMAT object
> in the mapfile to get nice-looking antialiasing over the entire map.
QGIS can easy produce the mapfile and the map in various format (agg,
png, gif, jpeg, etc.) using the Mapserver Export plugin. What you have
to do is, add shapefile to the QGIS project and then click the
MapServer Export plugin and fill up the form.
QGIS can do mapnik map using QuantumNik plugin as base map for
Mapserver, Geoserver, New QGIS Server (Map Server), etc.
Noli
More information about the Discuss
