[OSGeo-Discuss] Batch geocoding
Pieter De Graef
pieter.degraef at geosparc.com
Fri Feb 4 08:48:12 EST 2011
When we created the GeoCoder plugin for Geomajas we faced that same
problem. The google geocoder has a few drawbacks that makes it unsuitable.
In the end we used the Yahoo service together with the Geonames service,
with pretty good results.
Hope that helps.
On 02/04/2011 02:34 PM, JP Glutting wrote:
> Hello,
> I have a large set of addresses (around 150k) that I need to geocode
> for a study (my Masters thesis on heat-related mortality). I am
> looking into different solutions, but I can't find anything that seems
> like it would work properly.
> I could script a solution using Google's map API, but there is a limit
> of 2,500 addreses per day (I can get around them with a little patience).
> Right now the best solution I am looking at geopy for geocoding
> addresses (http://code.google.com/p/geopy/). It seems like a good
> system, I think I can use it to pull addresses out of my database and
> write back coordinates. There is one thing that I am not sure, about,
> though, is whether I am actually allowed to use the Google API without
> my use being liked to a specific web page. The terms of service and
> form for getting a Google API key require a URL linked to a Google
> account. In fact, it looks like the API can only be used through a web
> site:
> "5.2 _Account Key_. After supplying Google with your account
> information and the URL of your Maps API Implementation, and
> accepting the Terms, you will be issued an alphanumeric key
> assigned to you by Google that is uniquely associated with your
> Google Account and the URL of your Maps API Implementation. Your
> Maps API Implementation must import the Google Maps APIs using
> this key as described in the Maps APIs Documentation
> <http://code.google.com/apis/maps/documentation/>, and Google will
> block requests with an invalid key or invalid URL. You may only
> obtain and use a key in accordance with these Terms and the Maps
> APIs Documentation <http://code.google.com/apis/maps/documentation/>."
> So it looks like I can't even get it to work without a URL.
> I can always write a script that loops through results extracted from
> the database, creates URLs and parses the XML results one at a time,
> but that seems like a fairly inelegant solution.
> Does anyone have any good ideas about how to geocode a few thousand
> addresses?
> Many thanks,
> JP
> Discuss mailing list
> Discuss at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/discuss
Pieter De Graef
Community Manager
GeoSparc nv.
http://www.geosparc.com/
Chairman of the Geomajas project
http://www.geomajas.org/
URL: http://lists.osgeo.org/pipermail/discuss/attachments/20110204/be1e741c/attachment.html
More information about the Discuss
