[OSGeo-Edu] Moodle login
Markus Neteler neteler.osgeo at gmail.com
Wed Oct 10 16:00:36 EDT 2007
Hi Moodle interested people,
today I got notified that the login into Moodle isn't that obvious.
So I have added instructions where to obtain the OSGeo
single signon login (note that the Wiki is still separate since
not yet hosted on OSGeo infrastructure).
Now it is explained at
http://test.osgeo.net/moodle/login/index.php
Cheers
Markus
PS: for moodle admins: The text is located here:
 Site Administration
 - Users
    - Authentication
        -> page bottom field "Instructions"
On 7/20/07, Tyler Mitchell (OSGeo) <tmitchell at osgeo.org> wrote:
> Hi all, in this morning's meeting (which I just caught the tail end
> of), Gary Watry was talking about an online tool called Moodle which
> has been using for distributing curriculum.  The question I had was
> if there was an easy way to use our existing Drupal CMS to do what
> was needed - but from what I now see of Moodle, I wouldn't want to
> try to replicate it with Drupal.
> Indeed, many people that blog about this kind of stuff look at using
> both Drupal and Moodle (and others) together to meet their needs.  So
> I personally have no problem trying out Moodle to handle the academic
> side of things.
> In fact I installed it on the OSGeo test server.  If you already have
> an OSGeo user account (aka LDAP account, the one used behind
> www.osgeo.org), then you should be able to log in an play around
> right away.
More information about the Edu_discuss mailing list
