FW: [OSGeo-Edu] Subversion strategy questions
Jorge Gaspar Sanz Salinas xurxosanz at gmail.com
Fri Jan 25 13:31:36 EST 2008
2008/1/23, Landon Blake <lblake at ksninc.com>:
> -----Original Message-----
> From: Landon Blake
> Sent: Wednesday, January 23, 2008 9:22 AM
> To: 'Frank Warmerdam'
> Subject: RE: [OSGeo-Edu] Subversion strategy questions
> Frank Wammerdam wrote:
> "On the whole DocBook issue - we tried using DocBook for a while for
> MapServer docs and ended up abandoning it because installing and getting
> to understand DocBook tools was too hard for many potential
> contributors."
> I also identified this as the major challenge when I looked at Docbook.
> I was all full of steam for the format until I started reading about
> what was necessary to convert the format in to PDF. It didn't look like
> a process for the faint of heart.
> At a minimum it looks like I would need to complete the following steps
> to perform a conversion:
> Install and learn how to use an XSLT Stylesheet Processor.
> Import the Docbook DTD into the processor.
> Import the conversion stylesheet into the processor.
> Run the conversion in the processor.
> This isn't exactly a one-click task, but perhaps it could be made into
> one.
> I wonder how one would control things like margin width and font style
> when generating PDF documentation from Docbook. Is anyone familiar with
> how this works in the conversion process?
Hi Landon again ;)
It's mainly in Spanish, but maybe you find useful the article I'm
writing for the Girona Meeting about OSGeo Spanish LC. It's in the
OSGeo SVN.
https://svn.osgeo.org/osgeo/community/presentations/20080303-Girona/OSGeo_Spanish/
You'll find an ant build file for linux systems (I'm working on a
Debian box) so you only need to install the proper packages (xalan,
fop, jai, docbook-xml, docbook-xsl) and run ant to generate the HTML
or the PDF.
Sorry, the README is also in Spanish :S
Of course you can always use the old DSSL stylesheets and OpenJade....
Cheers
Ingeniero en Geodesia y Cartografía
http://www.geomaticblog.net
http://www.prodevelop.es
More information about the Edu_discuss mailing list
