[fdo-commits] r838 - in branches/3.2.x/Utilities/SchemaMgr: Inc/Sm Inc/Sm/Ph Src/Sm/Ph
svn_fdo at osgeo.org svn_fdo at osgeo.org
Thu Mar 15 11:25:37 EDT 2007
Author: brentrobinson
Date: 2007-03-15 11:25:37 -0400 (Thu, 15 Mar 2007)
New Revision: 838
   branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/BaseObject.h
   branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/SchemaElement.h
   branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/BaseObject.cpp
   branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/DbObject.cpp
   branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Field.cpp
View Support: Prevent "item already in collection" message when view is based on 2 tables with same name but in different datatores.
Modified: branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/BaseObject.h
--- branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/BaseObject.h	2007-03-15 13:18:01 UTC (rev 837)
+++ branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/BaseObject.h	2007-03-15 15:25:37 UTC (rev 838)
@@ -55,12 +55,25 @@
     const FdoSmPhDbObject* RefDbObject() const;
     FdoPtr<FdoSmPhDbObject> GetDbObject();
+    /// Overridden to generate a unique name qualified by owner and database, since
+    /// a base object collection can contain objects from different owners and databases.
+    virtual FdoString* GetName() const;
+    /// Get the referenced object's unqualified name
+    FdoStringP GetObjectName() const;
     /// Get the referenced object's owner name
     FdoStringP GetOwnerName() const;
     /// Get the referenced object's database name
     FdoStringP GetDatabaseName() const;
+    // returns number of times this base is referenced by child.
+    FdoInt32 GetBaseRefCount() const;
+    // Increment number of times this base is referenced by child
+    void AddBaseRef();
 protected:
     /// unused constructor needed only to build on Linux
     FdoSmPhBaseObject();
@@ -73,11 +86,13 @@
     virtual bool Delete() {return true;}
 private:
+    mutable FdoStringP mQName;
     FdoStringP mOwnerName;
     FdoStringP mDatabaseName;
     FdoPtr<FdoSmPhDbObject> mDbObject;
+    FdoInt32 mBaseRefCount;
 typedef FdoPtr<FdoSmPhBaseObject> FdoSmPhBaseObjectP;
Modified: branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/SchemaElement.h
--- branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/SchemaElement.h	2007-03-15 13:18:01 UTC (rev 837)
+++ branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/SchemaElement.h	2007-03-15 15:25:37 UTC (rev 838)
@@ -41,7 +41,7 @@
     const FdoSmSchemaElement* GetParent() const;
     /// Returns the name of the schema object.
-    FdoString* GetName() const;
     /// Get the fully qualified name for this element.
     /// This varies between element type so some types override this
Modified: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/BaseObject.cpp
--- branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/BaseObject.cpp	2007-03-15 13:18:01 UTC (rev 837)
+++ branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/BaseObject.cpp	2007-03-15 15:25:37 UTC (rev 838)
@@ -28,7 +28,8 @@
     FdoSmPhDbElement(name, (FdoSmPhMgr*) NULL, parent, FdoSchemaElementState_Detached ),
     mOwnerName(ownerName),
-    mDatabaseName(databaseName)
+    mDatabaseName(databaseName),
+    mBaseRefCount(1)
     if ( ownerName == L"" )
         mOwnerName = parent->GetParent()->GetName();
@@ -41,7 +42,8 @@
     FdoSmPhDbElement(dbObject->GetName(), (FdoSmPhMgr*) NULL, parent, FdoSchemaElementState_Detached ),
     mOwnerName(dbObject->GetParent()->GetName()),
     mDatabaseName(dbObject->GetParent()->GetParent()->GetName()),
-    mDbObject(dbObject)
+    mDbObject(dbObject),
+    mBaseRefCount(1)
@@ -64,11 +66,29 @@
 FdoSmPhDbObjectP FdoSmPhBaseObject::GetDbObject()
     if ( (wcslen(GetName()) > 0) && (!mDbObject) )
-        mDbObject = GetManager()->FindDbObject( GetName(), GetOwnerName(), GetDatabaseName() );
+        mDbObject = GetManager()->FindDbObject( FdoSmPhDbElement::GetName(), GetOwnerName(), GetDatabaseName() );
     return mDbObject;
+FdoString* FdoSmPhBaseObject::GetName() const
+    if ( mQName == L"" ) {
+        mQName = FdoStringP(L"\"") + GetOwnerName() + L"\".\"" + FdoSmPhDbElement::GetName() + L"\"";
+        if ( GetDatabaseName() != L"" ) {
+            mQName = FdoStringP(L"\"") + GetDatabaseName() + L"\"." + mQName;
+    return mQName;
+FdoStringP FdoSmPhBaseObject::GetObjectName() const
+    return FdoSmPhDbElement::GetName();
 FdoStringP FdoSmPhBaseObject::GetOwnerName() const
     return mOwnerName;
@@ -79,3 +99,12 @@
     return mDatabaseName;
+FdoInt32 FdoSmPhBaseObject::GetBaseRefCount() const
+    return mBaseRefCount;
+void FdoSmPhBaseObject::AddBaseRef()
+    mBaseRefCount++;
Modified: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/DbObject.cpp
--- branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/DbObject.cpp	2007-03-15 13:18:01 UTC (rev 837)
+++ branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/DbObject.cpp	2007-03-15 15:25:37 UTC (rev 838)
@@ -169,7 +169,8 @@
     if ( baseObjects->GetCount() == 1 ) {
         FdoSmPhBaseObjectP baseObject = baseObjects->GetItem(0);
-        rootObject = baseObject->GetDbObject();
+        if ( baseObject->GetBaseRefCount() < 2 )
+            rootObject = baseObject->GetDbObject();
     return rootObject;
@@ -195,7 +196,8 @@
         const FdoSmPhBaseObject* baseObject = baseObjects->RefItem(0);
-        rootObjectName = baseObject->GetName();
+            rootObjectName = baseObject->GetObjectName();
     return rootObjectName;
@@ -209,7 +211,8 @@
-        rootOwnerName = baseObject->GetOwnerName();
+            rootOwnerName = baseObject->GetOwnerName();
     return rootOwnerName;
@@ -223,7 +226,8 @@
-        rootDatabaseName = baseObject->GetDatabaseName();
+            rootDatabaseName = baseObject->GetDatabaseName();
     return rootDatabaseName;
@@ -1101,8 +1105,16 @@
     while ( baseObjRdr->ReadNext() ) {
         FdoSmPhBaseObjectP newBaseObject = NewBaseObject( baseObjRdr );
-        if ( newBaseObject )
-            mBaseObjects->Add( newBaseObject );
+        if ( newBaseObject ) {
+            FdoSmPhBaseObjectP currBaseObject = mBaseObjects->FindItem( newBaseObject->GetName() );
+            if ( currBaseObject )
+                // Base object already in collection, just add a base reference.
+                currBaseObject->AddBaseRef();
+            else
+                // Not in collection, add it.
+                mBaseObjects->Add( newBaseObject );
Modified: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Field.cpp
--- branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Field.cpp	2007-03-15 13:18:01 UTC (rev 837)
+++ branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Field.cpp	2007-03-15 15:25:37 UTC (rev 838)
@@ -158,8 +158,9 @@
     FdoStringP colSyntax;
-    if ( GetColumn() ) {
-        colSyntax = GetColumn()->GetName();
+    FdoSmPhColumnP column = GetColumn();
+    if ( column && column->GetExists() ) {
+        colSyntax = column->GetName();
     return colSyntax;
More information about the fdo-commits mailing list
