[fdo-commits] r796 - branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common
svn_fdo at osgeo.org svn_fdo at osgeo.org
Thu Mar 15 11:26:43 EDT 2007
Author: brentrobinson
Date: 2007-03-15 11:26:42 -0400 (Thu, 15 Mar 2007)
New Revision: 796
   branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/SchemaMgrTests.cpp
   branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/SchemaMgrTests.h
Added test for view based on 2 tables with same table name.
Modified: branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/SchemaMgrTests.cpp
--- branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/SchemaMgrTests.cpp	2007-03-15 13:19:04 UTC (rev 795)
+++ branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/SchemaMgrTests.cpp	2007-03-15 15:26:42 UTC (rev 796)
@@ -1260,6 +1260,156 @@
+void SchemaMgrTests::testViews ()
+    StaticConnection* conn = CreateStaticConnection();
+    FdoPtr<FdoIConnection> fdoConn;
+    try
+        char prvenv[100];
+        sprintf( prvenv, "provider=%s", conn->GetServiceName() );
+#ifdef _WIN32
+        _putenv( prvenv );
+#else
+        putenv( prvenv );
+#endif
+        FdoStringP provider = conn->GetServiceName();
+        // Sets the other env.
+        UnitTestUtil::SetProvider( conn->GetServiceName() );
+        printf( "Creating original schema ...\n" );
+        conn->connect();
+        FdoSchemaManagerP mgr = conn->CreateSchemaManager();
+        FdoSmPhGrdMgrP phMgr = mgr->GetPhysicalSchema()->SmartCast<FdoSmPhGrdMgr>();
+        FdoSmPhDatabaseP database = phMgr->GetDatabase();
+        GdbiConnection* gdbiConn = phMgr->GetGdbiConnection();
+        GdbiCommands* gdbiCommands = gdbiConn->GetCommands();
+        FdoStringP datastore = phMgr->GetDcOwnerName(
+            UnitTestUtil::GetEnviron("datastore", DB_NAME_SUFFIX)
+        FdoStringP fdatastore = phMgr->GetDcOwnerName(
+            UnitTestUtil::GetEnviron("datastore", DB_NAME_FOREIGN_SUFFIX)
+        FdoSmPhOwnerP owner = phMgr->FindOwner( datastore, L"", false );
+        if ( owner ) {
+            owner->SetElementState( FdoSchemaElementState_Deleted );
+            owner->Commit();
+        owner = database->CreateOwner(
+            datastore,
+            false
+        owner->SetPassword( L"test" );
+        FdoSmPhOwnerP fowner = phMgr->FindOwner( fdatastore, L"", false );
+        if ( fowner ) {
+            fowner->SetElementState( FdoSchemaElementState_Deleted );
+            fowner->Commit();
+        fowner = database->CreateOwner(
+            fdatastore,
+            false
+        fowner->SetPassword( L"test" );
+        FdoSmPhTableP tableA = owner->CreateTable( phMgr->GetDcDbObjectName(L"TABLE1") );
+        FdoSmPhColumnP column = tableA->CreateColumnInt32( phMgr->GetDcColumnName(L"ID"), false );
+        tableA->AddPkeyCol( column->GetName() );
+        column = tableA->CreateColumnInt32( phMgr->GetDcColumnName(L"PARENT_ID"), false );
+        column = tableA->CreateColumnInt16( phMgr->GetDcColumnName(L"INT16_COL1"), false );
+        FdoSmPhTableP tableB = fowner->CreateTable( phMgr->GetDcDbObjectName(L"TABLE1") );
+        column = tableB->CreateColumnInt32( phMgr->GetDcColumnName(L"ID"), false );
+        tableB->AddPkeyCol( column->GetName() );
+        column = tableB->CreateColumnInt32( phMgr->GetDcColumnName(L"PARENT_ID"), false );
+        column = tableB->CreateColumnInt16( phMgr->GetDcColumnName(L"INT16_COL1"), false );
+        database->Commit();
+        FdoSmPhGrdOwnerP grdOwner = fowner->SmartCast<FdoSmPhGrdOwner>();
+#ifdef RDBI_DEF_ORA
+        grdOwner->ActivateAndExecute( L"grant select on table1 to public" );
+#endif
+        FdoStringP createViewSql = FdoStringP::Format(
+            L"create view view1 ( id, int16_col1, int16_col2b ) as select a.id, a.int16_col1, b.int16_col1 from %ls a, %ls b where a.id = b.parent_id",
+            (FdoString*)(tableA->GetDbQName()),
+        grdOwner = owner->SmartCast<FdoSmPhGrdOwner>();
+        grdOwner->ActivateAndExecute( (FdoString*) createViewSql );
+        createViewSql = FdoStringP::Format(
+            L"create view view2 ( id, int16_col1, int16_col2b ) as select a.id, a.int16_col1, b.int16_col1 from %ls a, %ls b where a.id = b.parent_id",
+            (FdoString*)(tableB->GetDbQName())
+        mgr = NULL;
+        phMgr = NULL;
+        conn->disconnect();
+        delete conn;
+        conn = CreateStaticConnection();
+        conn->connect();
+        mgr = conn->CreateSchemaManager();
+        phMgr = mgr->GetPhysicalSchema()->SmartCast<FdoSmPhGrdMgr>();
+        printf( "Autogenerating schema from datastore ...\n" );
+        fdoConn = UnitTestUtil::CreateConnection(
+            false,
+            false,
+            DB_NAME_SUFFIX
+        FdoPtr<FdoIDescribeSchema>  pDescCmd = (FdoIDescribeSchema*) fdoConn->CreateCommand(FdoCommandType_DescribeSchema);
+        FdoFeatureSchemasP schemas = pDescCmd->Execute();
+        FdoFeatureSchemaP schema = schemas->GetItem(0);
+        FdoClassesP classes = schema->GetClasses();
+        CPPUNIT_ASSERT( classes->GetCount() == 3 );
+        FdoClassDefinitionP classDef = classes->GetItem( table2class(phMgr, L"VIEW1") );
+        FdoDataPropertiesP idProps = classDef->GetIdentityProperties();
+        CPPUNIT_ASSERT( idProps->GetCount() == (SupportsBaseObjects() ? 1 : 0) );
+        classDef = classes->GetItem( table2class(phMgr, L"VIEW2") );
+        idProps = classDef->GetIdentityProperties();
+#ifndef RDBI_DEF_SSQL
+        CPPUNIT_ASSERT( idProps->GetCount() == 0 );
+#endif
+        UnitTestUtil::CloseConnection( fdoConn, false, DB_NAME_SUFFIX );
+        printf( "Done\n" );
+    catch (FdoException* e )
+        UnitTestUtil::FailOnException(e);
+    catch (CppUnit::Exception exception)
+        throw exception;
+    catch (...)
+        CPPUNIT_FAIL ("unexpected exception encountered");
 void SchemaMgrTests::testConfigError ()
Modified: branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/SchemaMgrTests.h
--- branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/SchemaMgrTests.h	2007-03-15 13:19:04 UTC (rev 795)
+++ branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/SchemaMgrTests.h	2007-03-15 15:26:42 UTC (rev 796)
@@ -31,6 +31,7 @@
     CPPUNIT_TEST (testGenConfig1);
     CPPUNIT_TEST (testGenKeys);
     CPPUNIT_TEST (testFKeys);
+    CPPUNIT_TEST (testViews);
     CPPUNIT_TEST (testConfigError);
 //    CPPUNIT_TEST (constraints);
 //    CPPUNIT_TEST (delFdoBr);
@@ -52,6 +53,8 @@
     // Also tests reverse-engineering foreign keys into Association properties for MySQL.
     virtual void testFKeys();
+    void testViews();
     virtual void testConfigError();
     void testGeometricProperties();
More information about the fdo-commits mailing list
