[fdo-internals] Build warnings - PostGIS and Boost...
Jason Birch Jason.Birch at nanaimo.ca
Fri Nov 9 17:27:50 EST 2007
It's warning about linking shared PostGIS against static Boost.
Is this something to be concerned about?
Jason
/usr/bin/install -c .libs/libPostGISOverrides-3.3.0.soT
/usr/local/fdo-3.3.0/lib/libPostGISOverrides-3.3.0.so
(cd /usr/local/fdo-3.3.0/lib && { ln -s -f libPostGISOverrides-3.3.0.so
libPostGISOverrides.so || { rm -f libPostGISOver
rides.so && ln -s libPostGISOverrides-3.3.0.so libPostGISOverrides.so;
/usr/bin/install -c .libs/libPostGISOverrides.lai
/usr/local/fdo-3.3.0/lib/libPostGISOverrides.la
PATH="$PATH:/sbin" ldconfig -n /usr/local/fdo-3.3.0/lib
Libraries have been installed in:
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the `-LLIBDIR'
flag during linking and do at least one of the following:
   - add LIBDIR to the `LD_LIBRARY_PATH' environment variable
     during execution
   - add LIBDIR to the `LD_RUN_PATH' environment variable
     during linking
   - use the `-Wl,--rpath -Wl,LIBDIR' linker flag
   - have your system administrator add LIBDIR to `/etc/ld.so.conf'
See any operating system documentation about shared libraries for
more information, such as the ld(1) and ld.so(8) manual pages.
 /bin/sh ../libtool --mode=install /usr/bin/install -c
'libPostGISProvider.la' '/usr/local/fdo-3.3.0/lib/libPostGISProv
ider.la'
libtool: install: warning: relinking `libPostGISProvider.la'
(cd /home/administrator/fdosvn/Providers/PostGIS/Src; /bin/sh ../libtool
--tag=CXX --mode=relink g++ -O2 -MMD -MT -o li
bPostGISProvider.la -rpath /usr/local/fdo-3.3.0/lib -shared -release
3.3.0 -L../../../Thirdparty/pgsql/lib Provider/libP
ostGISProviderSrc.la libPostGISOverrides.la
../../../Utilities/Common/libProvidersCommon.la
../../../Fdo/Unmanaged/Src/l
ibFDO.la ../../../Thirdparty/boost/stage/lib/libboost_thread-mt.a
../../../Thirdparty/boost/stage/lib/libboost_date_time
-mt.a -lpq )
*** Warning: Linking the shared library libPostGISProvider.la against
the
*** static library
../../../Thirdparty/boost/stage/lib/libboost_thread-mt.a is not
portable!
the
*** static library
../../../Thirdparty/boost/stage/lib/libboost_date_time-mt.a is not
portable!
More information about the fdo-internals mailing list
