[fdo-internals] FDO 3.3 compatible MrSID and ECW Plugins
Wed Nov 21 00:08:42 EST 2007
Folks,
Tom requested I prepare FDO 3.3 compatible versions
of the MrSID and ECW plugins.  FDO 3.3 is using
GDAL 1.4.x and VC8, so I prepared plugins that should
work with any GDAL 1.4 / VC8 "normal" build.
The plugins can be found at:
  http://home.gdal.org/dl/gdal14_vc8/mrsid_plugin_gdal14_vc8.zip
  http://home.gdal.org/dl/gdal14_vc8/ecw_plugin_gdal14_vc8.zip
It should be possible to unpack these in a mapguide
bin directory (ie. where mgserver.exe sits).  They will
drop supporting DLLs for MrSID or ECW libraries in
the same directory, and put the plugin in a gdalplugins
subdirectory.
BTW, I looked i the file:
  fdosdk-3.3.0_win32_release.tar.gz
And it *appears* the gdal14.dll in this tarfile is linked
against oci.dll.  So I wasn't actually able to do any testing
to confirm that the gdal14.dll from the 3.3.0 fdo binaries
would work with the plugins I prepared.  Instead I ended up
testing them with a gdal14.dll I built myself.  So i'm not at
all certain things will be in good shape.
I'd note I also packaged up a full GDAL 1.4.3 VC8
SDK build at:
  http://home.gdal.org/dl/gdal14_vc8/gdal143_vc8_sdk.zip
I imagine it should be able to copy the gdal14.dll out
of this sdk and replace the one in the fdo alpha
release.
If someone can try the plugins I prepared, I'd like to
see us capture the steps and file locations in a wiki
page somewhere approach (fdo trac? mapguide trac?)
Best regards,
More information about the fdo-internals mailing list
