[fdo-internals] Remove Generated Files
Mateusz Loskot mateusz at loskot.net
Mon Oct 29 16:48:18 EDT 2007
Mateusz Loskot wrote:
> Jason Birch wrote:
>> It would be nice if the trunk could remain as accessible as possible to
>> non-developers.  I don't know what kind of effort there is using
>> autotools, but just wanted to get a word in.
> In many projects, especially in GNU world, ./configure is forbidden in
> CVS/SVN as a dynamic content.
> So, there is a special script provided that generates it for you.
> For example, in GDAL ./configure lives in the repository,
> but there is also autogen.sh script which can be used to generate
> configure. Let's assume there is no ./configure in FDO repo, then
> if you want to build SVN version, you have to run:
> ./autogen
> ./configure
> make
> make install
> So, it's just one step more.
One more example, GEOS uses this approach.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
More information about the fdo-internals mailing list
