[fdo-internals] PATCH : PostGIS provider patch 3.4
Bruno Scott bscott at geomapgis.com
Thu Apr 17 09:50:12 EDT 2008
This is a pretty big Patch I know.
Many of the tickets were related in a way or another.
It has became very hard to have lots a small patches
The next patch will be : one ticket for one patch 
Ticket fixed by this patch
#94  Generate extent for features assigned to default spatial context
#106 PostGIS provider cannot delete a feature class
#171 Fdo Postgis Autogenated identity property is mandatory
#178 PostGIS : Can't insert in a non-feature class
#232 Fdo Postgis null and not null filter does not work
#233 Fdo Postgis in and not in filter does not work
#234 Fdo Postgis currently does not support anything but lowercase
identifiers
#235 Fdo Postgis Exception with insert
#236 Fdo Postgis does not support non spatial classes
#241 Implement Support for SelectAggregates, SpatialExtents and Count
#310 PostGIS provider : change class naming convention without ~
#311 PostGIS provider : mismatch between FdoGeometricTypes and
FdoGeometryType
#312 PostGIS provider : remove boost_date_time dll dependency
#313 PostGIS provider : can't filter,insert or update date/datetime
#314 PostGIS provider : check-out/check-in crashes Autodesk Map
I have included binaries, it’s easier to test than recompiling everything
These binaries have been tested on Map 2009
Patches and binaries for Branch\3.3 and for 3.2.3 will follow
Bruno
http://www.nabble.com/file/p16744011/PostGIS_trunk_patch.zip
http://www.nabble.com/file/p16744011/PostGIS_trunk_binaries.zip
View this message in context: http://www.nabble.com/PATCH-%3A-PostGIS-provider-patch-3.4-tp16744011s18162p16744011.html
Sent from the fdo-internals mailing list archive at Nabble.com.
More information about the fdo-internals mailing list
