[fdo-internals] PATCH : PostGIS provider patch 3.4
Mateusz Loskot mateusz at loskot.net
Fri Apr 18 03:40:04 EDT 2008
Bruno,
I'll review it today when I'm back from school.
I don't have usable FDO environment now, but I'll see if I can configure
one so I can run and test this patch.
I'll drop you a note.
Thank you very much to you and your team!!!
-- Mateo
Bruno Scott wrote:
> This is a pretty big Patch I know.
> Many of the tickets were related in a way or another.
> It has became very hard to have lots a small patches
> The next patch will be : one ticket for one patch 
> Ticket fixed by this patch
> #94  Generate extent for features assigned to default spatial context
> #106 PostGIS provider cannot delete a feature class
> #171 Fdo Postgis Autogenated identity property is mandatory
> #178 PostGIS : Can't insert in a non-feature class
> #232 Fdo Postgis null and not null filter does not work
> #233 Fdo Postgis in and not in filter does not work
> #234 Fdo Postgis currently does not support anything but lowercase
> identifiers
> #235 Fdo Postgis Exception with insert
> #236 Fdo Postgis does not support non spatial classes
> #241 Implement Support for SelectAggregates, SpatialExtents and Count
> #310 PostGIS provider : change class naming convention without ~
> #311 PostGIS provider : mismatch between FdoGeometricTypes and
> FdoGeometryType
> #312 PostGIS provider : remove boost_date_time dll dependency
> #313 PostGIS provider : can't filter,insert or update date/datetime
> #314 PostGIS provider : check-out/check-in crashes Autodesk Map
> I have included binaries, it’s easier to test than recompiling everything
> These binaries have been tested on Map 2009
> Patches and binaries for Branch\3.3 and for 3.2.3 will follow
> Bruno
> http://www.nabble.com/file/p16744011/PostGIS_trunk_patch.zip
> http://www.nabble.com/file/p16744011/PostGIS_trunk_binaries.zip
Mateusz Loskot
http://mateusz.loskot.net
More information about the fdo-internals mailing list
