[fdo-internals] Several small code changes in fdo to compile against pedantic mode default in gcc 4.3.2
Helio Chissini de Castro helio at kde.org
Fri May 30 13:56:13 EDT 2008
Hi
I'm fighting against new gcc 4.3.1 and their new pedantic mode.
Is worth the work, since new gcc is way faster to compile among other
benefits.
The issue is that fdo have several points that we need include explicit
headers, like string.h.
The other issue is that some small code standards shout too much warnings, na
if -ansi mode is enabled, it not compile at all.
I just started this tests since i improved the cmake build to have proper
linux flags and start the windows side too, and convert UnitTests to a more
recent cppunit.
Despite cppunit part, can i be able to have access and commit the small fixes
for new gcc, like add missing required includes ?
Thanks in advance
KDE Project
Brasil and South America Primary Contact
More information about the fdo-internals mailing list
