[fdo-internals] Use of SQL pass through
Haris Kurtagic haris at sl-king.com
Thu Jun 25 11:05:21 EDT 2009
Orest,
Provider would return primary key from arbitrary SQL statement ? This
RFC is about executing any type of SQL statement and returning some type
of FDO class for it, if so then no primary key there.
" don't need to use it if they don't want", but provider would need to
do some processing for it and it eventually would not be used.
Class definition can include information which it can extract from
database after executing SQL statement. Objects to be created can
include this information.
Again, I don't see additional value if those information about executed
SQL statement would be put inside FDO object (in many cases it wouldn't
be even possible or even desirable) over what is currently posible with
"regular" database drivers. I can see lot of additional work to make it
possible and even than in many cases those won't be used. There is also
performance penalty.
Haris
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Orest
Halustchak
Sent: Thursday, June 25, 2009 4:35 PM
To: FDO Internals Mail List
Subject: RE: [fdo-internals] Use of SQL pass through
But the class definition includes additional information that you
wouldn't find just by getting information a property at a time. The idea
with the feature reader is that it is returning "objects" based on a
class definition rather than arbitrary collections of columns. The
addition of getting a feature reader from the SQL command is intended to
be optional for the caller, they don't need to use it if they don't
want. But the class definition includes extra information such as the
identity properties (primary key) so that the caller can determine the
unique identity of these objects, which is important if the caller is
going to draw these objects and then enable a user to edit them or go
back to the data store for other information about the object.
Thanks,
Orest.
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Haris
Kurtagic
Sent: Thursday, June 25, 2009 10:10 AM
To return FDO class from any SQL will require extra processing from
provider. This processing will in best case add unnecessary overhead to
provider.
My suggestion is to enable application to get info about returned
columns trough feature readers. Same way as non-fdo applications are
doing it right now.
I don't see any advantage in trying to squeeze SQL statement result into
FDO class and I can see many problems there.
Even opposite, I would prefer to optimize FDO commands. Instead trying
to guess what type of SLQ statement application has executed or parsing
current FDO filters it would be better that we would have very simple
"query window of data" type of command in FDO. That is something not
directly related to this RFC but it is direction where I think FDO could
go. Less overhead and simpler commands for most usual  tasks.
Haris
Halustchak
Sent: Thursday, June 25, 2009 3:17 PM
There hasn't been too much feedback on this.
Haris, for SQL selects, to return data in a feature reader, we either
can simply describe the results of the select and produce a temporary
fdo class for the reader or if the SQL select happens to correspond
cleanly to an existing feature class (e.g. something as simple as select
* from roads), then we can use that fdo class instead. The goal is to
make it easier for application developers that can use either fdo
selects or sql selects and process the results with a common reader.
Anybody else have comments? I know we got some feedback from Jackie.
Thanks,
Orest.
[mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of Greg Boone
Sent: Thursday, June 04, 2009 11:39 AM
Hi Haris,
Can you provide some examples of non-DDL use cases that would make the
proposal too complex? I also feel we should limit the discussion at this
time to read only DML statements such as Select.
Greg
Kurtagic
Sent: Thursday, June 04, 2009 5:41 AM
I would like to divide this and answer in two parts.
Part with Parameters direction is something we need. As it is already
written , mostly to be able to execute and get results from stored
procedures.
About executing SQL statements and trying to squeeze result of it inside
FDO class/schema, I think it is too complex and in my mind without
chance to be successful. There is so many cases in which it can't be
done properly. If we are missing some info about result of execution of
SQL we could look into existing specs like ODBC and add those. I agree
FDO application should be able to get all necessary info about executed
SQL so app can be written in generic way but I don't see putting that
info in FDO class or reengineering sql etc.. I believe what can be done
with api's like odbc is ok for fdo api too.
Haris
Halustchak
Sent: Wednesday, June 03, 2009 3:28 PM
Subject: [fdo-internals] Use of SQL pass through
I would like to solicit feedback, discussion, and suggestions on
requirements and issues that we are seeing with the FdoISQLCommand which
is used for the purpose of SQL pass through for some of the RDBMS-based
providers.
Please see the discussion below.
Thanks,
Orest.
... snipped ...
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20090625/a800df04/attachment-0001.html
More information about the fdo-internals mailing list
