[fdo-internals] Dropping off PSC
Leaf Li leaf.li at autodesk.com
Mon Nov 8 08:55:01 EST 2010
Hi Daniel,
I turn off firewall in my computer and get the following error message.
In C:\DOCUME~1\asus\LOCALS~1\Temp\: "C:\Program Files\CVSNT\cvs.exe" -q -Q co -c
CVSROOT=:pserver:cvs.maptools.org:/cvs/maptools/cvsroot:
Empty password used - try 'cvs login' with a real password
cvs [checkout aborted]: unrecognized auth response from cvs.maptools.org: cvs [pserver aborted]: /cvs/maptools/cvsroot:: no such repository
Error, CVS operation failed
Actually I can use my TortoiseCVS to check out other depot. Can you double check whether MITAB depot really supports anonymous login.
Thanks,
Leaf Li
________________________________________
From: fdo-internals-bounces at lists.osgeo.org [fdo-internals-bounces at lists.osgeo.org] on behalf of Daniel Morissette [dmorissette at mapgears.com]
Sent: Thursday, November 04, 2010 10:50 PM
To: FDO Internals Mail List
Subject: Re: [fdo-internals] Dropping off PSC
Daniel Morissette wrote:
> Leaf Li wrote:
>> By the way, do you know the address of MITAB SVN depot. I just know GDAL/OGR SVN depot contains it.
> It's a CVS repository on the maptools.org server, the CVSROOT is:
>   :pserver:dmorissette at cvs.maptools.org:/cvs/maptools/cvsroot
> and you should be able to checkout the latest source using user
> "anonymous" and an empty password.
Um... I've been too quick on the copy/paste. The CVSROOT for anonymous
access would be:
  :pserver:anonymous at cvs.maptools.org:/cvs/maptools/cvsroot
... and then "cvs login" with an empty password...
... and then "cvs checkout mitab" to get the source...
Daniel
Daniel Morissette
http://www.mapgears.com/
fdo-internals mailing list
fdo-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-internals
More information about the fdo-internals mailing list
