[fdo-internals] CMake build fixes (Re: FDO 3.7 beta2 timeframe)
Johan Van de Wauw johan.vandewauw at gmail.com
Mon Oct 15 01:15:40 PDT 2012
I'm extremely busy this week but I may have a look next week to the other
issues you're talking about.
Anyway: since the autotools build is not using sonames anywhere it should
be dropped here for every library. Better not to have a soname than one
that is not correct or that is not used.
The version number of FDO should then be added to all public libraries; in
the same way as it is done for the auto* build now. But you have to do this
manually; AFAIK there is no switch in cmake that corresponds to libtool
--release.
But before rushing to making these changes: what is the original reason
that we have two build systems? We could also consider changing the
autotools build to optionally use dynamic libraries...
Johan
On Mon, Oct 15, 2012 at 7:56 AM, Jackie Ng <jumpinjackie at gmail.com> wrote:
> Hi Johan,
> Now that MapGuide 2.4 is out the door, I've had time to take another look
> at
> this.
> My question is should this SONAME omission be done for all FDO shared
> libraries? Or just the "public" ones that would be linked by MapGuide
> (libFDO, libExpressionEngine)?
> I also noticed that the file listing of a cmake build differs from an
> automake one. There are some libs that are being created as shared
> (dynamic)
> libraries instead of static ones. Doing a SHARED -> STATIC add_library
> replacement on the applicable CMakeLists.txt caused a whole load of linker
> errors. Obviously something extra needs to be done here.
> For packaging purposes, the cmake build should be producing the same set of
> output files as the automake one.
> Got any extra notes to share?
> - Jackie
> http://osgeo-org.1560.n6.nabble.com/FDO-3-7-beta2-timeframe-tp4898809p5008588.html
> Sent from the FDO Internals mailing list archive at Nabble.com.
> fdo-internals mailing list
> fdo-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-internals
URL: <http://lists.osgeo.org/pipermail/fdo-internals/attachments/20121015/8e4f3eed/attachment.html>
More information about the fdo-internals mailing list
