[fdo-trac] #178: PostGIS : Can't insert in a non-feature class
FDO trac_fdo at osgeo.org
Wed Nov 21 03:00:10 EST 2007
   Reporter:  bscott            |       Owner:  mloskot
       Type:  defect            |      Status:  new
   Priority:  blocker           |   Milestone:  3.3.0
  Component:  PostGIS Provider  |     Version:  3.2.0
   Severity:  1                 |    Keywords:
External_id:                    |
 In the PostGis provider it is not possible to insert in a non-feature
 class .
 The provider search first for the classdefinition in the "schemaDesc"
 And the schemadesc is only filled with the values from the postgis
 geometry_columns table.
 Here is the piece of code that make that call failed:
 FdoIFeatureReader* InsertCommand::Execute()
     FdoPtr<FdoClassDefinition>
 classDef(schemaDesc->FindClassDefinition(mClassIdentifier));
     if (!classDef)
       throw FdoCommandException::Create(L"[PostGIS] InsertCommand can not
 find class definition");
 Orest Halustchak wrote:
 FdoIInsert is supposed to work on non-feature classes as well. There is no
 separate insert command for these.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/178>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
