[fdo-trac] #177: Support Non-ASCII7 database element names
FDO trac_fdo at osgeo.org
Fri Nov 30 15:00:03 EST 2007
 Reporter:  brentrobinson               |         Owner:  brentrobinson
     Type:  enhancement                 |        Status:  closed
 Priority:  major                       |     Milestone:  3.3.0
Component:  GenericRdbms API            |       Version:  3.3.0
 Severity:  2                           |    Resolution:  fixed
 Keywords:  ASCII7 create table column  |   External_id:
Comment (by brentrobinson):
 Revision: 3591
 Author: brentrobinson
 Date: 2:27:36 PM, Friday, November 30, 2007
 Message:
 Ticket#177: Fixed problem where Schema Manager was unable to located FDO
 Spatial Index columns for geometric property with non-ASCII7 name. Also,
 allow order by columns in Schema Manager queries to be collated.
 Modified :
 /trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Ph/Rd/OwnerReader.cpp
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.cpp
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoSchemaRollbackTest.cpp
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/Common/SchemaMgrTests.cpp
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalBender.xslt
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalFormatter.xslt
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/gen_default1_SqlServer2005_master.txt
 Modified :
 /trunk/Providers/GenericRdbms/Src/UnitTest/gen_default1_SqlServer_master.txt
 Modified :
 /trunk/Utilities/SchemaMgr/Inc/Sm/Lp/GeometricPropertyDefinition.h
 Modified : /trunk/Utilities/SchemaMgr/Inc/Sm/Ph/Mgr.h
 Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Lp/ClassDefinition.cpp
 Modified :
 /trunk/Utilities/SchemaMgr/Src/Sm/Lp/GeometricPropertyDefinition.cpp
 Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Lp/SchemaElement.cpp
 Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Ph/AssociationReader.cpp
 Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Ph/ClassWriter.cpp
 Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Ph/DbObject.cpp
 Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Ph/DependencyReader.cpp
 Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Ph/Mgr.cpp
 Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Ph/Mt/ClassReader.cpp
 Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Ph/Mt/PropertyReader.cpp
 Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Ph/Mt/SchemaReader.cpp
 Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Ph/Owner.cpp
 Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Ph/SADReader.cpp
 Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Ph/SOReader.cpp
 Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Ph/Table.cpp
Ticket URL: <http://trac.osgeo.org/fdo/ticket/177#comment:2>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
