[fdo-trac] #121: PostGIS extents calculations do not appear to be working
FDO trac_fdo at osgeo.org
Tue Sep 11 17:58:54 EDT 2007
   Reporter:  jbirch            |       Owner:  mloskot
       Type:  defect            |      Status:  new
   Priority:  major             |   Milestone:  3.3.0
  Component:  PostGIS Provider  |     Version:  3.2.2
   Severity:  3                 |    Keywords:
External_id:                    |
 I'm not sure if this is a PostGIS Provider bug, or a MapGuide problem, but
 I'll start here.
 When I load a set of tables that have a relatively small extent on a local
 arbitrary scale (somewhere around -100, -100, 100, 100, you can get the
 actual extents from the provider log) the layer will can be created and
 visualized in the !MapGuide Studio layer preview screen just fine.
 However, when adding one of these layers to a new Map definition, the data
 extents of the map are not updated correctly to reflect the extents of the
 layer, and need to be set manually.
Ticket URL: <http://trac.osgeo.org/fdo/ticket/121>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
