[fdo-trac] #315: SQLite: Conversion does not translate geometry types
FDO trac_fdo at osgeo.org
Fri Apr 18 22:05:29 EDT 2008
   Reporter:  jbirch           |       Owner:  traianstanev
       Type:  defect           |      Status:  new
   Priority:  major            |   Milestone:
  Component:  SQLite Provider  |     Version:  3.3.1
   Severity:  3                |    Keywords:
External_id:                   |
 When transferring from my SDF file (which contains multiple tables) to
 SQLite using the converter, the supported geometry types do not appear to
 be set correctly.  A table that only supports polygons shows as supporting
 all types in Studio after the conversion.  I can provide the source and
 destination files if you'd like.
 I haven't had a chance to see what happened in geometry_columns in the
 meantime.
Ticket URL: <https://trac.osgeo.org/fdo/ticket/315>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
