[fdo-trac] #314: PostGIS provider : check-out/check-in crashes Autodesk Map
FDO trac_fdo at osgeo.org
Mon Apr 21 13:57:08 EDT 2008
 Reporter:  bscott            |         Owner:  mloskot
     Type:  defect            |        Status:  closed
 Priority:  blocker           |     Milestone:  3.4.0
Component:  PostGIS Provider  |       Version:  3.2.0
 Severity:  1                 |    Resolution:  fixed
 Keywords:                    |   External_id:
Old description:
> As soon as we hit the check-out or the check-in features command it
> crashes Autodesk Map 2008 ( this append also with Map 2009 )
> I found that if we turn off the transaction capability
> It works ok.
> I will use that approach for the moment
> but i think we will have to check the Transaction support to see what's
> going on.
New description:
 It works ok.
 going on.
 Related ticket #325
Comment (by mloskot):
 I submitted the transactions issue as separate ticket (#325)
Ticket URL: <http://trac.osgeo.org/fdo/ticket/314#comment:4>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
