[fdo-trac] #317: SQLite: Valid extents not being returned.
FDO trac_fdo at osgeo.org
Sat Apr 19 01:02:22 EDT 2008
   Reporter:  jbirch           |       Owner:  traianstanev
       Type:  defect           |      Status:  new
   Priority:  major            |   Milestone:
  Component:  SQLite Provider  |     Version:  3.3.1
   Severity:  3                |    Keywords:
External_id:                   |
 Not sure if this is a bug or an enhancement request...
 In order for a Layer to be previewed in MapGuide, valid data extents need
 to be known.  I'm not sure if this information is pulled from the spatial
 context, or a separate call.
 In any case, it is not working with this provider, and it makes it
 difficult to see what you're working with in MapGuide until you get the
 layer into a map with either other known-extent layers, or manually set
 map extents.
 If you're willing to add this capability to the provider, I can do a bit
 of research and see where Studio is getting its extents info from.
Ticket URL: <https://trac.osgeo.org/fdo/ticket/317>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
