[fdo-trac] #317: SQLite: Valid extents not being returned.
FDO trac_fdo at osgeo.org
Sat Apr 19 01:02:40 EDT 2008
 Reporter:  jbirch           |         Owner:  traianstanev
     Type:  defect           |        Status:  new
 Priority:  major            |     Milestone:
Component:  SQLite Provider  |       Version:  3.3.1
 Severity:  3                |    Resolution:
 Keywords:                   |   External_id:
Old description:
> Not sure if this is a bug or an enhancement request...
> In order for a Layer to be previewed in MapGuide, valid data extents need
> to be known.  I'm not sure if this information is pulled from the spatial
> context, or a separate call.
> In any case, it is not working with this provider, and it makes it
> difficult to see what you're working with in MapGuide until you get the
> layer into a map with either other known-extent layers, or manually set
> map extents.
> If you're willing to add this capability to the provider, I can do a bit
> of research and see where Studio is getting its extents info from.
New description:
 In order for a Layer to be previewed in !MapGuide, valid data extents need
 difficult to see what you're working with in !MapGuide until you get the
 map extents.
Ticket URL: <https://trac.osgeo.org/fdo/ticket/317#comment:1>
FDO <http://fdo.osgeo.org/>
Feature Data Objects
More information about the fdo-trac mailing list
